Question about KCL Smartboard Unifi 55 Projector Replacement Lamp With Housing
How do i get the white and black dots off my smartboard?
Why is there vertical lines on a smartboard UF65 projector?
1,white spots appeared on screen,means the DMD chip is
broken,you need a new DMD chip.I supply the DMD chip and the
price is USD120
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel,
Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
any questions, feel free to contact me
have a nice day!
Email/Skype: lampdeng@hotmail.com
Aug 11, 2014 | Smartboard Smart Board UF65 Projector Lamp
Black and white dots on screen
Hi Emmanuel,
I think your projector lamp and LCD area is dusty.
please use pressurized air can and clean the area.also check the dust filter.
do it carefully.
regards,
nuwan
Jan 27, 2014 | NEC NP215 Portable Projector
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
Black dots projected on my 3m scp716 projector
Actually, this is a known issue with this specific model as 3M has acknowledged. We bought 4 of these and 3 have had to be replaced in 3 years because of this exact issue. It requires the mainboard to be replaced and it is almost as expensive to do this as to buy a new unit. 3M has been know help to us on this even through we bought the entire setup (Projector, Arm, Smartboard) and spent over $15000.
Oct 17, 2012 | 3M 78-927719-5 - SCP716 DLP PROJ 2400LUMEN
I HAVE RED DOTS ALL OVER ANY BLACK COLOR OF THE PICTURE
Could be whats known as dead pixels, this is tested be showing up a black or white screen. Microsoft paint or word will do. If an area always has dots then dead pixel. However if it doesn't constantly remain a dot then, some-thing else. Dead pixels come about due to age.
A technician will be able to diagnose your problem by performing white screen test.
damnor01
Nov 17, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
Smartboard will not work
If you tried 7 different laptops yeah, the problem could be with the smartboard. Try another one and see what happens.
Otherwise we'll just be guessing.
Feb 25, 2009 | Toshiba Satellite A60 Notebook
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Ge sca1001hss01 otc advantum microwave
First, order by number. Some illustrations are general. Second, you may find a board rebuilder who will fix yours or exchange it.
I've done this and found that the correct product was sent and worked well.
Dec 13, 2007 | GE JVM1650 1000 Watts Microwave Oven
KCL Smartboard Unifi 55 Projector Replacement Lamp With Housing Logo
29 people viewed this question
Top KCL Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a KCL Office Equipment and Supply Expert? Answer questions, earn points and help others
