Question about Stuhrling Marquis Gentry Watch
Www.unicrom.de start na batterijwissel
Check N serie R6679202
The most secure way to check a Rolex is to go to a specialized trade. The following Link gives you a overview of specialized dealers available in USA: http://www.rolex.de/de/rolex-dealers/dealer-locator/unitedstates
Best Regards
Mike (Germany)
Sep 08, 2014 | Rolex Watches
The most secure way to check a Rolex is to go to a specialized trade. The following Link gives you an overview of specialized dealers available in USA: http://www.rolex.de/de/rolex-dealers/dealer-locator/unitedstates
Best Regards
Mike (Germany)
Jul 31, 2014 | Rolex Watches
Is my Rolex authentic ?
Best Regards
Mike (Germany)
Jul 27, 2014 | Rolex Submariner Date : 16800 : Stainless...
Nuty na akordion-walce
www.akordeon.pl/index.php
Jun 30, 2014 | Watches
I am unable to set time in watch Nako NA-823A
NAKO NA-823A Instructions
Turn Alarm on or off:
-Press the S and D buttons simultaneously
Display Date:
-Press the D button
Set time and date:
-Press the M button to switch modes in this sequence: stop watch>set alarm>set time>time.
-The S button will allow you to select seconds, minutes then hour, then day, month and weekday.
-Use the D button to clear seconds to zero, or move minutes and hours and date up by a single increment.
-Press and hold D for two seconds to move minutes and hours rapidly.
-Press and hold D while pressing and holding S moves through AM/PM and 24 hour (H) modes.
Use stopwatch:
-Press the M button until you arrive at the stopwatch.
-Press D to start and stop
-Press S to clear.
Display alarm time:
-Press the S button while time is displayed.
Jan 14, 2013 | Watches
-Press the S and D buttons simultaneously.
Display Date:
-Press the D button.
Set time and date:
Use stopwatch:
-Press S to clear.
Display alarm time:
Ik heb net een festina herenhorloge gekocht de F16388 daar heb ik geen handleiding bij gekregen en ik krijg maar de datum en dag niet goed ingesteld, kunt u mij daarbij helpen?
Hallo,
Ik ben ook zo stom geweest om zo'n festina F16388 te kopen en dan nog op het vliegtuig, je weet wel via Airshop ( 85 Euro )
Inderdaad ook geen handleiding aanwezig.
Na wat zoeken kan ik het volgende doorgeven
Instellingen
-Maand: boven de draaiknop: neem een stylo of potlood en druk zoveel keer tot je op de gewenste maand bent (voor nu AUG).
-Datum: trek de draaiknop los (naar rechts) en draai zo lang vooruit tot op de gewenste datum (voor vandaag 9).
-Dag en uur: trek de draaiknop los (naar rechts) en draai zo lang achteruit tot dag en uur samen juist staan (voor vandaag THU en 11u42).
Let hierbij dat de onderste kleine wijzerplaat nu tussen 11 en 12 zal staan.
Druk nu draaiknop terug in (naar links)
Veel succes
Francky
francky.arteel@pandora.be
Sep 26, 2010 | Festina Watches
Need help setting interval timer on timex w-191-na 100 lap memory. need to set to 1 min and 2 min and repeat 10 times
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Popular T5E931 100 Lap Ironman...
A premium problem
Beni maraming salamat saiyo,sa binibigay mo na link medyo,nahuhuli naako meron nang nakakuha ng Best solution.Magtatagalog nalang ako saiyo Ben,nakakahiya saiyo.Hindi kuna aaksayahin itong pagkakataon nato na hihingi ako ng tawad saiyo, "sorry talaga" tungkol doon sa pagkopya ng solution mo,"Cold solder"akala ko noon ok lang,dahil nakita ko sa iba na komopya din,sa solution ko .Dati noong una kung mga solution talagang tinatyp ko mabagal akong magtayp dahil hindi ako sanay sa pagtatatyp at saka sa computer .Kaya lagi akong nahuhuli,hindi ko rin alam ang pagamit ng mga links .Kaya noong nakita ko ang solution mo,akmang-akma sa problema,kalimitan kasi sa electronics epektibo ang cold solder talaga. Maganda ang pagkasulat mo,kaya kina copy paste ko at lagi kung ginagamit ko sa una sa "free solution", hindi ko ginagamit sa "premium solution",iniwasan ko na magkasabay tayo,kaya lagi ako nakakuha ng FIXYA rating free solution. Sa kalaunan akala ko okey lang ginagamit kuna sa "Premium solution" pati,ang iniwasan kung mangyayari na magkakasabay tayo nangyari talaga. Kaya seguro nagagalit ka sa akin,pinopuna muna ang solution ko sa "Misubishi TV tungkol sa sagot ko na "DM" board ,binulgar mo sa lahat saan ko kinokopya yon at tungkul sa kotse din na ginu-googles ko kinuha ang sagot at totoo yon ang lahat nayan,pagtinatamad ako at nagmamadali ako,baka mahuhuli ang sagot ko.
Ang tingin ko seguro nanyayari ito dahil hindi ako nagrespond saiyo sa 'lounge'. Kaya hindi naako pumapasok sa lounge dahil lagi akong pinupuna nila,noon pa. Nagumpisa ito noong nakakuha ako ng FIXYA sa premium solution sa sagot ko sa kotse,tingnan mo ito dito nag-umpisa ang lahat; http://www.fixya.com/cars/t686411-engine_idle
Unang nagalit at nagkomento si ,robotek,tapos nagpa follow up si ekse,sinundan ni abrsvcs,at ibang pang expert na bilib na bilib kay ekse at robotek.Parang nag feel insecure sila pagnakafixya ka o best solution lang.Nakita muna cguro yon ginawa ni robotek sinulat niya ito http://www.fixya.com/ExpertsLoungeThreadView.aspx?thid=718401
Mula nito hindi naako pumassok sa lounge,nakakainis lang minabuting kunalang na huwag pansinin. Lagi ang komento nag googles copy paste,hindi daw ako technician. Maraming top expert nag googles din,si maiksi ,ginko nakasabay ko to sila,tinago ko lang sa premium.Si maiksi lang parang allergic sa akin.Madalas kaming magkasabay,mahilig siya sa maiksi sagot ,parang one liner lang,kaya insecure siya ,baka malaman na siya mahilig mag "place holder",pagwalang makakasabay,saka banatan niya maraming sagot at ang kustomer hindi nag repost kuha na niya. Lagi siyang sumisigaw ng place holder,totoo pala ang kasabihan "kung sinong nagsisili,siya ang hangan". Seguro kung hindi ako technician hindi ako makapasok dito disgrasya lang, ito ang dahilan ;
http://www.fixya.com/support/t668287-burn_resistor Naghahanap ako ng free download schematic diagram.Nagkataon iyon nagpapagaling ako sa operasyon ko sa gall blader.Seaman ako 3RD marine engineer,alam muna pag ang marino nasa lupa ubos talaga lalo na sa kalagayan ko nagkakasakit.May electronics shop ako sa Imus cavite isa at dalawa dito rin sa cebu .Sa pagka ngayon inabalahan ko ay "satellite unlimited" walang load-load,kuha ko diyan sa tondo 5,500 tapos ibinta ko dito sa cebu 25 to 20 thousand,sa bohol ,leyte at saka mindanao.Ang gusto ko sa fixya updated sa repair at makakuha ako ng idea.Sory talaga Ben at saka kay Marked ok lang yong koment mo...
Ikaw Ben tagasaan ka ?Saan ka dati nagtratrabaho..ito number ko 09068050462. Sory pala doon sa lounge bastos kasi yong taong yan si keamo,kabagobago lang niya,kung umasta parang sino.Galit siya sa pinoy tinira din niya si Namizka doon sa car aircon . Hinintay kulang magkamali siya at saka si abrsvs nayan.Etxt muna lang yong number mo...
Oct 01, 2008 | Watches
Stuhrling Marquis Gentry Watch Logo
20 people viewed this question
Top Stuhrling Watches Experts
ptpumpman
 Mikey
Mikey
Are you a Stuhrling Watch Expert? Answer questions, earn points and help others
