Question about KitchenAid KSF26C6XYY Side by Side Refrigerator 36"""
How to replace the KitchenAid refrigerator light W10279030 or W10412708?
Want to know how to dismount the light module.
Is there any aftermarket spark module available for a kitchenaid KGCS-1340P
Contact a local small appliance repair shop they will know this info and can supply the parts if available.
Sep 28, 2016 | KitchenAid Kitchen Ranges
How to dismount KitchenAid cooktop model KECT 365
Why not refer this issue directly to KitchenAid. Maybe they can explain the disparity between what the installation sheet shows and what you actually don't see.
Dec 30, 2013 | KitchenAid Cooktops
My 19 year old kitchenaid kbrs21k refrigerator still works fine BUT when i recently crammed too much stuff onto the top shelf i must have broken the plastic light cover which fell on top of the light bulb....
Take the bulb out and check the continuity. Then you should know if there is a fuse that needs replacing. If all is well make sure your new bulb doesn't have a bad element.
Dec 03, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid ice maker water flow will not activate
You can post your the problem at my site by clicking the link below. Then click on free diagnosis, enter model number and the details and it may take a couple days to get the answer, but free. Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice Maker Motor replacement
I was able to remove the motor module by pressing together the two tabs that held the left arm of the shut off bar to the motor module. I purchased a new KitchenAid motor module (substituted a part by the factory). I replaced the motor module and I now have ice making again. The only difference though is that with the new motor module, the on position with the shut off arm is know longer in a 3 o'clock position but more a 5 o'clock position.
Aug 02, 2008 | KitchenAid KSCS25FKSS Side by Side...
No Ice
Hold the flap in .....the light should go on solid as long as your hand isnt blocking the beam. There have been lots of modules (the motor and brain of the I/mkr) breaking. I recommend replacement of the IDIM. Is there any water in the mold?? Where are the ejector blades loacted?? Are they stuck down in the mold?? Do they rotate easlily by hand?? These are signs of the broken module.
Nov 25, 2007 | KitchenAid KSRA25ILSS Side by Side...
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSF26C6XYY Side by Side Refrigerator 36""" Logo
61 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
