Question about Garden
XT170 Line Trimmer/Brush Cutter TRIGGER - Garden
jgwhomeequip
  • 1902 Answers
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
  • 148 Answers
SOURCE: Need a manual for a RYOBI Model RY30530.
go to www.managemyhome.com and download a free copy of the manual.
Posted on Jul 16, 2009
  • 124 Answers
SOURCE: Muculloch brush cutter wont start. No spark.
If you have correctly diagnosed the problem as no spark, you will need to replace the ignition module. Unfortunately McCulloch dealers and McCulloch parts are very hard to find these days. If yoou do not have a dealer in yoour are who has the part you need, contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Posted on Sep 22, 2009
SOURCE: arbor stuck on gear head/bc26
I have the same problem. Any solution?
Posted on May 01, 2010
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
How do you remove the line trimmer attachment to attach the brush cutter blade
the nut holding the trimmer head on is a left hand thread so you have to turn it clockwise to undo it
when the head is off you put the next attachment on and do up the nut in the reverse direction
Oct 25, 2017 | Garden
I have a ryobi x 430 string trimmer. The timing belt came off as mentioned in other postings and I put it back on according to online tips. It ran well for a while. Now, it is hard to start, but it...
It is possible that the timing gear jumped a tooth. Take off valve cover and check to make sure timing marks line up. Other than that check other things like carb adjustment, good gas, air filter and other general tune up things.
Aug 27, 2013 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have a L123 Husquravana brush cutter and I am looking for the lock nut that holds on the trimmer head. I am looking for the size to the lock bolt.
The trimmer head is not held on by a nut, the whole trimmer head is spun onto a 10mm male output shaft, to remove the trimmer head lock the geabox by inserting a 6mm pin through the top of the gearbox, there is a hole to take it, this will lock the drive disc, you can then turn the whole trimmer head clock wise ( left hand thread ) and remove the trimmer head. Parts are available for the trimmer head, it depends on which head you have, manual feed, or bump feed.
Nov 22, 2012 | Husqvarna 123/223L Brush Cutter Kit...
Stihl HT75 will not throttle up
take off the muffler and try it if ok with the muffler off open the muffler and clean the carbon from the screen
Apr 19, 2012 | Oregon Scientific Complete Carburetor for...
How do I install a brush cutter on my 128LD trimmer?
The 128LD is a detachable shaft machine, there are a number of attachments, hedge trimmer, brush cutter, brush, blower etc, there is a alloy clamp at the bottom of the machines tube, just push the attachment tube into the clamp, there is a locating hole so as you know it is fully home, now screw the clamping screw fully down to lock in place
May 12, 2011 | Husqvarna Garden
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
Stihl FS40 Runs for 60 secs at low RPM with the trigger fully depressed - then quits
had the same problem.
in the fuel tank is a gas filter and a fuel line. replace both.
the line gets soft with age and collapse and restricts fuel flow.
while u are at it replace the other two fuel lines as well. easy to get to when u have the cover off.
Aug 10, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
