Question about Pyle Pt3300 Amplifier
What is the main tranformers number for pt-3300pyle pro
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pyle Master
  • 924 Answers
It will be written on the transformer, but you will only be able to get an exact duplicate at Pyle.
Posted on Jan 14, 2015
I have a Samsung HLN617W and am relocating to Germany. I'm thinking that the TV will not work properly since the Germans use the frequency of operation of 50hz and the TV is set to the American Frequency...
No,the main problems USA,European,and Asia are the NTSC or PAL tv signals frequencies.Sometimes the 110 volts or 210 volts,need a tranformer for that to step up or down the voltages for that.The Hez,the tranformers inside the power board convert for that.The colors wheel is dead,it dead!Will not make no diffrent in spinning RPM revolutions of the colors weel.
Apr 02, 2010 | Samsung HLN617W 61" Rear Projection HDTV
When turned on makes slight buzzing noice and no picture or sound
Ur FBT,the flyback tranformer is dead.The big black block of plastic with a red wire or gray hook up to a board.That is dead.This FBT,help get high voltage to the CRTS.Take it to the shop or call the repairman.This involving high voltage work,don't have the right equipements or no experience in electronics,don't tries to replaced the FBT.It involved with 1200 hundred high voltages.
Mar 23, 2010 | Panasonic PT-65WX51 65" Rear Projection...
Philips 200W B flashing on for a second then goes black
This is beause 2 Capactors of the internal power tranformer were damaged. If you know how to open the casing and then open the tranformer to replace those 2 tranformer, 100% sure it will return to normal and last long.
Jan 15, 2010 | Philips 200WB7 (Silver) Monitor
I have a Panasonic 53" PT-53x54- 53" turns on for 5 seconds then
It is very common for the high voltage tranformer or flyback to wear out and not provide adequate power to the tv. You can test them with an ohmmeter to see how much powrer is being sent to the main circuit board. You can get parts at tigerdirect.com
Dec 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
No tranformer mains no booklet to work the printer and no power lines
Hi there..
I would say, go to your local electronics shop with a note marking down the electrical requirements of your printer (Voltage, connector size) and ask them to create a power transformer for your printer.
Then, go to the printer's company website, and look for "driver downloads" under "support". Find your printer, download and install.
Tom
Jun 20, 2009 | HP Photosmart C6180 All-In-One InkJet...
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Pyle Pt3300 Amplifier Logo
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
