Question about Kitchen Appliances - Others
Delta kettles My kettle has three temperature settings, 60 degrees, 80 degrees and 100 degrees (boiling point) It heats up to 80 degrees, gives a whistle (as though it had boiled) and switches off. What may be the problem and are spares available in the U.K. ?
  • 274 Answers
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Posted on Sep 11, 2007
SOURCE: Boiling
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
Posted on Feb 28, 2008
jerryg50
  • 1689 Answers
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Posted on Apr 29, 2008
  • 3 Answers
SOURCE: kettle shuts off before boiling?
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
Posted on Apr 12, 2009
  • 35 Answers
SOURCE: the power switch light on my kettle comes on but
1. Check the continuity on the power switch
2. Check to see if any thermal cut-out is open circuit
3. Check to see if the element has gone open circuit.
Any open circuit indicates the part will require replacing. Given the cost of the kettle, if the element has gone open circuit it may be worth considering replacing the kettle itself.
Posted on Mar 25, 2010
Testimonial: "thanks for the very helpful fast respnse"
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
"On" switch blinks, kettle won't heat
In case you are still watching this issue for a solution - I'm afraid my assessment of the company troubleshooting support and of this particular issue is that we are out of luck.
I have the same problem. Have downloaded manuals - very little information except for use...ie, don't get them wet.
I have contacted the company - they asked me for the same information I gave them in the original troubleshooting request...
We bought a new one - fortunately on sale at Target. The blinking light is the normal indication - lack of heat and boiling is the problem.
Our new pot boils on both bases...old pot clicks and then just sits there with a blinking light - the light should blink until the temp is reached.
I intend to return the old pot to Target and move on....I suspect there is a burned out coil but, it is too hard to troubleshoot and won't be able to be fixed.
I suspect that a better (more expensive) pot might have more durable coils...but, we'll see how long the new one lasts.
Aug 29, 2012 | Oster 1.7 L Variable Temperature Electric...
The kettle leaks at where teh handle attaches at the bottom
Join the club ---I'm taking ours back this afternoon to BB&B. It's still under warranty and we have the receipt.
Nov 14, 2010 | Krups FLF2 Cordless Electric Kettle
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Krups electric kettle leaks
You cannot fix it when they split like that.
Apr 01, 2010 | Krups Stainless Steel Electric Kettle...
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
Boiling
Nov 07, 2007 | Bravetti EK119H Electric Kettle
Kettle shuts off before boiling?
Aug 29, 2007 | Braun WK600 Cordless Electric Kettle
Kitchen Appliances - Others Logo
24 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
