Question about Canon imageRUNNER 5020 Copier
Where is hard Drive located on Canon imageRunner 5020 Copier
gunninfo
  • 59 Answers
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
  • 89 Answers
SOURCE: how to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Posted on Nov 25, 2009
brett207
  • 231 Answers
SOURCE: Canon Imagerunner 5020 E00000-0000 Error Code
E000 error means the fixing assembly is overheating.
You will need a Service technician to fix this.
Posted on Dec 07, 2009
  • 149 Answers
SOURCE: Describe how to remove hard drive from canon
what you will have to do is remove the back cover.
then you will need to remove the thin metal cover laying flat cover on the back half of the copier just under the doc feeder. should be 3 screws.
then there is a metal box that holds the main controller on the right. if you open that you will see the IDE cable which will run up and out of that box and will run up under a thin metal plate that should be held in by 2 screws. if you remove those screws you should be able to see the hd .
if you can't get it out and or find it please call me it might be easier to explain. over the phone.
C & S Canon Copier Repair
(858)414-8475
Posted on Jun 17, 2010
Testimonial: "I was able to find the HD and now I am going to replace it. Thank you very much for the answer it was very helpfull. I even call the tech and he helped me out over the phone. FixYa I think you are doing a great service!!!!!"
canontech
  • 1219 Answers
SOURCE: i would like to Reset/Retrieve Password for Copier
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Posted on Jun 29, 2010
Testimonial: "THANKS A LOT THAT WAS SWEET IT WORK THE MAGIC GOD BLESS"
Error code e3000 0000
All problems associated with this copier can be found in its user manual. The link below is the user manual for the model associated with this question. A simple search in the manual of the error code should result in the answer to your question.
http://www.retrevo.com/support/Canon-5020-Copiers-manual/id/23385dj783/t/2/
Mar 21, 2011 | Canon imageRUNNER 5020 Copier
How to install the program for canon 1r 5020 hard drive. I want to clone the hard drive on it. Thank a lot for advice.
I don't know how you can do this without removing it from the copier and using some kind of computer software to do it. There's no way of doing it within the copier that I'm aware of. If you're trying to reinstall the system softwaree you have to have access to the Canon Service Support Tool. All Canon Techs should be able to get it. Good Luck
Jan 29, 2011 | Canon imageRUNNER 5020 Copier
The display sceen is blank & you see the number on the bottom of the display? Your hard drive has crashed... You will mostly need to have the hard drive replaced to solve this problem.... Good Luck
Jun 04, 2010 | Canon imageRUNNER 5020 Copier
E000540-0001
E540 There is an upper tray ascent/decent error. (finisher)
Apr 09, 2010 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 5020 Copier not printing parallel attached
open your cd and try PrinterDriver Installer from misc folder
Apr 06, 2010 | Canon imageRUNNER 5020 Copier
Problem printing PDF's
I think there are some softwere error in the copier hard disk,
but before confirm try with
pcl 5c and use copier with lan cable or you can also use pcl5 5000-6000 series driver (don't necessary 5020-6020)
please reply for next step
Apr 29, 2009 | Canon imageRUNNER 5020 Copier
Where is the hard disk drive located?
the hdd is under your scan glass near the right side of machine
Mar 17, 2009 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 5020 Copier Logo
56 people viewed this question
old marine
old marine
