Question about IMAGISTICS Toner for ix2700 ix2701 484-5
Machine error 6A - IMAGISTICS Toner for ix2700 ix2701 484-5
Machine error 6A
Fuser Thermistor or Halogen lamp defective. maybe you need to replace the whole Fuser
Oct 10, 2014 | Brother MFC-8460N Laser Printer
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Dec 05, 2012 | Brother DCP-8020 Laser Printer
WHEN I TURN ON MY MACHINE BROTHER MFC 8440 I SEE ON THE SCREEN ERROR MACHINE 6A I NEED A SOLUTION
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
Jan 08, 2011 | Brother MFC-8440 All-In-One Laser Printer
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Jan 26, 2010 | Brother MFC-8440 All-In-One Laser Printer
Machine error 6a Brother 8840D
1) Unplug machine.
2) Hold down menu key while plugging in machine.
3) Enter 99 while holding down menu key
4) After it says "PLease wait" hit the stop/exit button to get out of the maintenance mode
Nov 16, 2009 | Brother MFC 8840D All-In-One Laser Printer
Brothers MFC 8220
It sounds like your machine has a mechanical malfunction and will need to be serviced.
Aug 19, 2008 | Brother MFC-8220 Fax
IMAGISTICS Toner for ix2700 ix2701 484-5 Logo
15 people viewed this question
Top IMAGISTICS Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an IMAGISTICS Office Equipment and Supply Expert? Answer questions, earn points and help others
