Question about Sharp Audio Players & Recorders
SHARP Hi-Fi Stereo (CD-BP2000) - Sharp Audio Players & Recorders
Stereo turns on shuts off after few seconds
This is a bad power supply. You have to do some serious work at the component level of the unit to fix it.
Jan 22, 2014 | Sharp Electronics - Xldk257n - Xl-Dk257n...
Need manual for a Sharp Computer Controlled Stereo Cassette Deck Model rt 3388a
Try Hi Fi Engine or get a paper one from Stereomanuals dot com where the best paper manuals do exist.
Aug 03, 2012 | Pioneer Audio Players & Recorders
CD burned on my computer won't play back on my Sony Mini Hi-Fi Component System MHC-NX1. I'm using Memorex Music CD-R and the burned CD will play back on my other stereo systems.
you have probles with a driver try to unistall the driver on the cd or dvd burner and automatic it will install the driver the pc will look for the driver on c:hdd if the porblem continue call 956 400 4141 I'm a computer technician send me you info and i will repair you computer problem.
Nov 27, 2010 | Sony 720W 5-Disc Mini Hi-Fi Component...
Protect error on model # CD BA200 Sharp Stereo
If you are a technician desolder the Audio amplifier IC,and check if the stereo turn on but with no sound.If the stereo turn on the audio amplifier IC is in short circuit and need to be replaced.
Good luck
Jun 05, 2009 | Sharp CD-BA200 CD Shelf System
Can i connect my sterio to tv
Yes, if it has Audio Out phono (usually colour coded Red & White) sockets on the rear of the DVD. Then connect to the audio IN of the Hi-Fi unit, which again may probably be phono type sockets.To hear the audio from the Hi-Fi you will probably have to select Aux as the input source on the Hi-Fi eg where you normally select CD/Radio etc. This is the common type of set up, but may vary slightly depending on the make of the stereo
Apr 01, 2009 | Panasonic Televison & Video
USER MANUAL
can u give me correct detail!
Jun 17, 2008 | Samsung Televison & Video
CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Apr 09, 2008 | Sharp XL-HP515 CD Shelf System
Data Products BP2000 printer (Digital LP29)
One oof my customer is seeking this dataproduct bp2000 with or fp2000. Anyone can source this for me?
Henry@scientek.co.id
Aug 27, 2007 | Dataproducts FP 2000A Matrix Printer
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
