Question about Emporio Armani Watches
How to remove a fixed watch bezel
How to remove a fixed bezel from a Armani meccanico ar-4604 as watch face is to big to be removed from the rear of the watch as the hands have fallen of the face I want to replace hands back on the watch face
escapement
  • 2334 Answers
SOURCE: AR 1029 armani watch replacement strap
All the info you should be able to find here:
www.emporioarmaniwatches.com
You can email, get customer support, call by phone or place an order.
If you can't find it there, try to buy it on ebay. Alternatively you can visit online shops by typing the name and model of your watch into your browser.
Don't forget to rate, please.
Posted on Jan 19, 2009
  • 188 Answers
SOURCE: How do I safely remove the crown of SEIKO ladies wristwatch
it might just lightly push on but not expert at this. clocks do. and some watches do. thats a fact.
Posted on Mar 26, 2009
escapement
  • 2334 Answers
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Posted on Apr 03, 2009
  • 5 Answers
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Posted on Jan 04, 2010
  • 2501 Answers
SOURCE: How to set the year for armani meccanico watch
The Armani site is not very helpful but try this one:-
The year should change when the month hand passes from December to January.
If you pull out the winder (it may need to be screwed out anticlockwise first), you should be able to find a position where the month can be changed. Wind the month hand passed December. If you need to advance it more than one year, then wind it backwards from January to December and then forwards again to January.
Posted on Jan 19, 2010
Is there a video for removing back of Emporio Armani AR 0540?
I wouldn't want to risk scratching up the back of an Armani. If you have a watch repair shop near you, it's better to take it there. I've taken several down for battery replacements, etc. and it has cost between $7-20, battery included. That said, I did find a video, but it's not for the exact Armani model and they used professional tools to do it. I saw another video where you could use standard tools, but you run the risk of gauling the metal on your watch in the process.
Sep 16, 2017 | Emporio Armani Watches
Broken Armani sign
Yes it can be fixed but may need a jeweller. You cannot take the glass face out on it own, you have to remove the watch back plate and then pull out the watch mechanism. (Once the back plate is off removing the mechanism is not difficult) You then have access to both the inside glass face and the watch face. If you can do this you will need to glue the Armani logo with something like super glue, but not applied directly to watch, too risky. If you have tweezers hold the Armani logo in them. Use a pin and dip it into a small blob of super glue, apply the pin to the back of the logo and then place it on the watch face as quickly as possible and align. Once aligned apply a little pressure with the tweezers on the logo to help adhere, about 5 seconds, leave to dry and then put watch back together. If this all seems to difficult a jeweller can do it in about ten minutes.
Jan 08, 2014 | Watches
How do i tell if my emporio armani watch is real or fake, it has all the right markings has a black leather strap a green face and came in a lined armani pouch
how to tell if armani watch is fake or real,
its near impossible ! its one of the easiest watch to copy,
the movement is much the same, armani use seiko! most copies
are as good has the original, and the time and effort put into making
it are much the same!
Nov 22, 2011 | Giorgio Armani Emporio Armani AR0203...
My watch has stopped after a long time of not being used how much will it cost to have it repaired and it also needs a new glass face as its scratched . (AR-0297)
The exact cost will vary depending on the shop you bring it to, and the overall condition of the watch. If the battery has just run out, it could be a very inexpensive fix ... but if the battery has died and corroded within the watch, it could be a much more difficult task, and cost a bunch more. If you are able to do so, I would recommend switching out the battery before you bring it anywhere as doing this yourself can save you some money and might get it running again in no time. As for replacing the face, I would recommend taking it to a repair shop for this (though once again I am not sure how much it would cost ... it depends on how much of the watch has to be taken apart to get the face off).
If your watch relies on a wound spring rather than a battery, then you would have to bring it to a professional to get the spring fixed (if that is why the watch has died). This is a delicate procedure, and requires a bit of skill and knowledge about watches to get it done right. This would be a bit more expensive to fix, but if your watch bears a lot of sentimental value, it could be worth it. If you have to wind the watch daily to keep it running, and winding it no longer works, then you are best to take it in to a repair shop and ask for an estimate.
Jun 07, 2011 | Giorgio Armani Armani Bracelet watch...
I bought aan armani meccanico watch and it is fast. The seller says it is normal and that all maccabico watches need time to adjust to the person using them.
No way man. A mechanical watch should be timed in the factory & the rate is in no way different on different people. They are simply hoping you will go away.
It will not be as accurate as a quartz watch, but you should be +/- 15 seconds a day on a product like that. They are not great, you are buying a name. But you still should get something for your money.
Feb 14, 2011 | Giorgio Armani Armani Meccanico watch...
How to install the timing belt on a ford focus 2.0 engine with a dual head cam?
mcdevito75 here, With the tools, Jacks and time and effort needed, It"s best and cheaper tohop do this $200.00 job, If your not familiar with this particular job, your looking at 4--6 hours, the shop does it in 3 hours.
Aug 19, 2010 | Giorgio Armani Emporio Armani Meccanico...
How to set the year for armani meccanico watch AR4218?
Jan 18, 2010 | Giorgio Armani Emporio Armani Sport Ar0532...
Watches Logo
37 people viewed this question
Top Emporio Armani Watches Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Emporio Armani Watch Expert? Answer questions, earn points and help others
