Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
How to reset lg washer - LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
LG Tromm Washing Machine no power unless I unplug it and reset it.
See if you can lift the top of the washer by unscrewing it from the back and you should find a code and test sheet in there. Very easy to follow and run the test.
Jan 02, 2016 | LG Washing Machines
What does error code 000000 -0000 means
How do you reset the error codes for an LG washer? - ImFee
www.imfee.com/how-do-you-reset-the-error-codes-for-an-lg-washer.html
Reset error codes on an LG washing machine by unplugging the machine, pressing ...locked 3G phones can be unlocked with the codes "123456" or "000000.
Jul 28, 2015 | Washing Machines
LG wm0532hw starts it's wash cycle then stops with the code LE flashing. Tried to reset the washer already and it did it again after reset. Tried no laundry in the cycle to see if it was to heavy and same...
check out youtube.com, repairclinic.com or appliancepartspros.com search for motor sensor replacement or hall sensor replacement. easy repair. $20 part. 30 minutes time. a know issue on earlier lg washers. lg has enhanced the part to make it more durable. make sure you get an lg part, not an oem equivalent part. part no. 6501KW2002A
Mar 18, 2015 | LG Washing Machines
LG washer reset
Why do you think the washer needs resetting?
Just unplugging the washer from the wall should do it.
Aug 10, 2014 | LG Washing Machines
LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
Dec 04, 2010 | LG WM2455 Front Load Washer
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
LG front load washer says LE on the desplay
LE is overloaded motor- most likely speed/direction sensor.
Call 1-877-714-7486 for LG reset proceedure and verification test.
Sensor is inboard of motor removed from the back.
Hope this helps
Jul 02, 2009 | LG WM1814CW Front Load Washer
Is there a reset button on the LG front load washer
No button, but LG customer service says unplugging the unit for 1 hour and then holding the power button while turning it on will reset the computer.
In my experience this does work, but I don't think it resets absolutely everything.
Another time I had a problem LG customer service told me to unplug the unit, hold the power button for 60 seconds and then plug it back in. I can't confirm if this works or not, but it is worth a try first (60 seconds is a lot shorter than 60 minutes...).
Feb 25, 2009 | LG WM2688H Front Load Washer
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
