Question about Air Tools & Compressors
I have a Dewalt D51822 Air Nailer. It suddenly is jamming and not cocking to shoot the nails. I have emptied the nails and oiled it, but it will not operate.
  • w_potter836 Jun 22, 2009
    The air pressure is not the problem. Neither is a warpped nose piece. The nose piece that is depressed to allow the trigger to fire seems to be the piece that is not working properly. How do I check out this mechanism?
  • 332 Answers
Is the stricking pin still straight,, sometimes when a nail jambs it takes out the firing pin,, you will need to take this apart and either order the part or buy a new gun
Posted on Jun 23, 2009
    Sergeant:
  • 296 Answers
Hi
The pressure regulator has a great deal of effect on the performance of the air tool. Regulators are sold by the volume of air (cfm)that they can handle. The more cfm the larger the pipe fittings on the regulator. A 1/4 fitting regulator will restrict the air somewhat compared to a 3/8. Another difference is weather moisture is present in the air. Moisture will temporarily help seal the orings, however too much water in gun will cut the orings. The air hose and fittings will also stifle performance. Long small diameter hose will lower pressure at the gun. This can be measured by installing a guage on a T fitting on the end of the hose and watch the pressure as you fire the gun. Larger fittings and hose ID will improve performance. Finally, your nail gun should work on both compressors. To make your nailgun work at home, (assuming that there are no air leaks) lube the headvalve parts with silicone grease. (sold at lowes in plumbing dept) For best performance, replace the orings in the head valve, examine the plastic parts where the orings contact and look for wear and tiny scratches (use magnify lense). Replace these worn parts along with orings. Replace the head gasket and make sure that the body and the head-cap are not warped. Place sheet of fine sandpaper on flat surface, with cylinder removed rub the body of the gun on paper a few times to check for warp. Do same with cap. Parts are available at www.toolpartsdirect.com.
hope u will b helpfull
regards
Posted on Jun 22, 2009
D51822 is nailing at a 45 degree angle instead of 90 degree
Joe,
hey not sure what the d51822 brand name is I work on bostitch as a service tech. so well the obvious question with the details you've given 45 degree angle? so are they bent over to get that angle? not sure how they can come out straight and get bent. ok the nose ( where the nail comes out) is it completely flat on the board? if so I would be nearly impossible to create a 45 angle. not doubting you. I work on F28WW bostitch thinking they are similar so, check the bolts on the top (loose or damaged) or the nose its self see if it is bent. it would be only slight because otherwise the driver ( what pushes the nail in) would get jammed and not fire at all .try that first thinking the nose is bent and if its bent its junk. because cracks are next and that's when really bad things happen fast.
Nov 15, 2015 | Dewalt Heavy - Duty 31° Clipped Head...
Air comes out the nose of my dewalt framing nailer
Again sounds like blown O ring give it a squirt of 3in1 oil and fire it several times (if oil is compatible in your gun). Repair center if that doesn't work. Trash can also get in the air orifice and stop moving parts from moving.
Dec 07, 2013 | Dewalt Air Tools & Compressors
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
Common problems dewalt clipped head framing nailer
there is NO easy solution for this, but unplug air and get a pair of safety glasses and a punch and try and knock the driver up into the tool away from the nail or if it is just jammed try and pull the nail out. You didn't really specify where the problem is. Let me know if you need more assistance.
Jan 05, 2012 | Dewalt D51822 Clipped Head 2Inch to...
I have a d51822 framing nailer that will shoot a nail but then not recoil to shoot the next nail, if you wait 10-20 seconds the gun will release air at the top of the gun and recoil
Most likely there is a problem with swollen orings between the cylinder and cylinder spacer (white plastic piece between cylinder and body ). Order the oring kit because nost likely when you take the gun apart the orings will fall apart. Dewalt used vinyl orings instead of viton on critical areas of the cylinder and these vinyl orings failed.
Sep 21, 2011 | Dewalt Clipped Head Framing Nailer
After shooting a nail, it fires out two more nails.
Dewalt has a new trigger valve to replace the original (part number 5140095-73). Not sure if the new valve is replacement to address an issue or natural progression. I would also replace the orings that make contact with the reference #55 on parts list called the bulkhead. There are four orings contacting the bulkhead that wear and may contribute to multi-fire. Parts are at dewalt service center or at www.toolpartsdirect.com Good luck
Jul 30, 2011 | Dewalt Heavy - Duty 31° Clipped Head...
D51822 framing nailer - worked just fine for a couple of hours then refused to fire nails. Pulling the trigger now results in a small puff of air. Current air pressure is set at 100 PSI. I have not used...
Yes your problem right about lubericatoin try putting lite oil in it hopefuly you didn,t taer one of the seals but if you did just standard o rings and you can get them at a hardware store and the gun is easy to rebuild
Nov 29, 2010 | Dewalt D51822 Clipped Head 2Inch to...
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Air Tools & Compressors Logo
48 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
