Question about Denon AVR-3300 Receiver
I have a buzz / static that appears for the first 15 minutes.
While my AVR-3300 is warming up (about 15 minutes or so) there is a static and buzz that will appear then dissappear completely. Leaving the amp on mute for about 10 minutes will bypass the problem, however I have a service manual and wouldn't mind troubleshooting the cause.
The AVR, and all perhipherals, are connected to a large regulated uninterruptible power supply and only recently started this behavior. Are there some electronic components within the amplifier that I should start the troubleshooting process with (i.e. amp section, pre-amp section, power regulator...)?
    Genius:
  • 1,175 Answers
Hi...
I just opened up an AVR3300..It's trouble is that it goes into stndby
at once.
The BIG power supply caps are VERY swelled at the top.
That would be my informed view on why it's bad.
I suggest you look at that being your possible trouble too.
Scott in Vermont
Posted on Jul 09, 2009
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
How to access denon avr-3300 system setup
First make sure that your remote control is set to "Amp" as it can control many different devices.
Then make sure that you have connected the Monitor Out socket on the receiver to your TV.
Next make sure your TV is set to show the picture from the input you connected to the Denon monitor out.
Now press set-up button on the remote and the System Setup menu should appear on your TV.
If this helps then please rate my answer,
Many thanks,
Chris
Mar 02, 2011 | Denon AVR-3300 Receiver
Denon AVR-3300 has a buzz from all 5 speakers during warm up.
Depending on the location you're living, try to connect a good ground to your system might solve the problem
Jun 20, 2009 | Denon AVR-3300 Receiver
Buzz or hum
My guess would be +and -12v supply to preamp opamps has ripple. (drycaps or bad solder). I may be able to get you a pdf service manual if needed. kstahl65@att.net
Jan 27, 2008 | Denon AVR-3300 Receiver
AVR-3300 Static and Sound Loss
The Denon Curse.......the connectors that the input boards ( up and down if your receiver is in the normal position ), plug into one of the 2 main boards on the bottom. These connectors are suspect and need to be cleaned and re-soldered. Same with the board that runs from the input side of the unit ( right behind the front panel, running across the unit ) to the amplifier board. Denons were HORRIBLE for bad connections with these. This is an involved repair requiring the entire thing to be pulled apart. It is not an afternoon job for a do-it-yourselfer, take it to an authorized Denon repair shop, as I GUARANTEE that they have seen this problem many times for all models from 2000-01-02-03. Good luck..... Rob
Jan 18, 2008 | Denon AVR-3300 Receiver
The AVR-3300 power-off to stand-by mode
You have a blown amp or a leaky cap and the unit is going in to save mode to avoid destrying the unit.
Take it in for a repair. I don't think it should run more than $50-$75 for a fix depending on what component is bad.
Nov 19, 2007 | Denon AVR-3300 Receiver
Denon AVR-3300 Receiver Logo
394 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
