Question about Pool & Spa
My skimmer line is stopped up, it will not skim from the top, the bottomline is fine. Could the valve havr something to do with that. Can I disassemble the valve and go in the line from the valve back to the pool and try to unstop it
  • Lisa Gray
    Lisa Gray Jun 23, 2009
    it is a inground fiberglass pool that is old. I did take the valve apart and tried to run a drain snake down the top skimmer line but the bends at the beginning will not llow me to do it. I feel that something is in the line. I have tried everything, using air and backpressure with water. nothing. I am afraid that it is going to get expensive to fix. It is not my pump that is the problem, I get a very good suction from the bottom, good pressure. Any help wll be appreciated. Lisa
  • james aurienne May 11, 2010
    inground or above
  • 93 Answers
IT COULD BE THAT THERE IS SOMTHING IN THE LINE IF YOU ARE NOT LOOSING WATER IT SHOULD NOT BE A BREAK IN THE LINE IF USING A WET VAC YOU HAVE TO MAKE SURE THAT WHEN TRYING TO VAC OR BLOW AIR YOU HAVE TO BE AIR TIGHT W FORCE A RAG ARUOND HOSE YOU MAY ALSO HAVE A AIR LOCK IF YOUR JUST OPENING THESE ARE CLEARED BY TAKING A GARDEN HOSE STICKING IT INTO SKIMMER WATER ON RAG AROUND HOSE TO MAKE TIGHT AND FILLING PUMP CUP TURN OFF BOTTOM LINE IF YOU CAN AND REPEAT TILL IT CLEARS
Posted on Jun 23, 2009
Wet set pump instruction manual
if you mean how to get it to skim the surface of pool for debris then it's a bit of trial and error im affraid , you need to get just enough water in the outside section to get it to allow a "flow" over top edge and fall down to center , but not too much to sink it and not skim surface, i sugest removing skimmer when pool is in use , it just gets sunk anyway from play .
Oct 13, 2012 | Intex Wet Set Above Ground Pool Surface...
What is a two pump skimmer?
There are some skimmers who use two pumps, one for pumping water through the skimmer, one for inducing air into the water with a needle wheel. For instance the Red Sea C-Skim 1200 use two pumps.
Aug 30, 2012 | A H Fabrications Fish
How does the Red Sea C-skim works?
I own the Red Sea C-skim 1200 protein skimmer. I can tell you that mine have two pumps, one to power the needle wheel and another to move the water from the tank through the skimmer then back to the tank.
How does the skimmer work?
The skimmer process is pretty simple in spite the fact that aquarium product manufactures want to present it like rocket since. Protein skimming is simply using bubbles to collect protein in the water and bring to the water's surface.
I'm trying to drain a pool that's Ben sitting for years full of nasty water. Pump works and operates but the fill pot on the pump itself will not stay full
Sounds like you're trying to pull water from skimmer and main drain. Soon as the level goes down, it sucks air from skimmer. Turn off skimmer line. If that's not possible, then cut off input side of pump(front pipe) and run new line to pool. Just lay it on top of ground and keep it below top by a couple of feet. This will stop all the **** on the bottom from plugging up the pump.
Mar 08, 2011 | Pentair Pool & Spa
When I backwash or rinse my pump reservoir fills to the top when I filter I have air bubbles at pool discharge and reservoir about 3/4 full and air is evident. Do I need to start digging up my skimmer line...
When backwashing or rinsing the same water is used as in filtering.(skimmer and main drain) so I don't think skimmer damage is the issue. Check if the pool water is low at the skimmer after the backwash cycle, Also check to see if the skimmer weir gate (flapper) is stuck in the upright position. I would suggest 2 main checks. Fill the pool higher than usual, back wash, ensure the pool water level is 1/2 way up the skimmer level and try again. Also, if your lines are valved right, shut off the skimmer during the filter cycle and see what happens. Lastly, the gasket on your multi-port valve may be bad.
Jul 16, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Zodiac Barracuda stops moving
Depending how you hook it up to the pool you need to be sure it is getting enough suction. If this is a dedicated line be sure that the valve is going all to the cleaner and back off till the pump quiets down. If you have it running through the skimmer be sure the dirveter valve is set to the proper suction and if you have a skimmer plate be sure your main drain is plugged off. Also check in the cleaner again. Things can hide in the diaprahm so be sure to use something that will let you go all the way beyond it or take apart to check if you have to. Good luck.
Dec 17, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Hairline crack in bottom of Hayward skimmer. Can it be repaired or reinforced without replacement as there is an access issue? Perhaps a thin PVC plate glued over the crack?
There are several brands of two part epoxies out there that work under water for this type of repair. Your local pool store should have something that you can mix and apply to seal the crack.
Oct 11, 2009 | Hayward Liner Pool Skimmer Sp1089 Deluxe...
When setting the pump to pull only from the skimmer on my in-ground pool, it doesn't **** enough water to keep the the suction pump full of water. I have to set it on main drain or ''skimmer & main...
There may be a partial blockage in the skimmer plumbing. If you lift out the basket, you may be able to see something there. If not, try a hose and flushing the lines.
Make sure the wear door is functioning properly also.
If this is not the issue, make sure that you have all the valves open so there is no restriction of flow.
Jul 10, 2009 | Pentair Bermuda Vinyl/Fiberglass Pool...
Pool & Spa Logo
591 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
