Is there a manual for prosound n88gu - Audio Players & Recorders
Prosound disco lights broken
more likly lazor. and personally i would leave it be. check for proper battety supplie amps and otherwise consult the designer and request proper instructions for bulb replacements, sometimes its an art. and sometimes its a recall. i personally would do without the lazar.
Jan 04, 2014 | Cars & Trucks
No Sound Output from Prosound 200 amplifier
check the remote wire its that its blue and runs from the amp to your head unit
Mar 06, 2013 | Car Audio & Video
ProSound 1600 Professional Power Amplifire, No Manuals, No Service, No Manufakturwebsite? Who can help???
Try on google, To do a search.There are sites where you can download manauls for no charge, I found the owners manaul for my adcom Power Amp that way. End it is over 15 years old.
Oct 21, 2012 | Audio Players & Recorders
Prosound 1000 amp protect light
If the amp has an overload protection to it, which is sounds like it does, there should be a reset for the amp or a method of resetting the amp to working condition. Go to the manufacturers website and look for that or send them an email. They will be able to direct you.
Sep 28, 2012 | Technical Pro Integrated Amplifier 1000...
No sound is coming out of speakers
do u have the sound car software installed? check u are plugged into the right port at reat of PC
Sep 05, 2010 | Inland ProSound 2000 Computer Speakers
Prosound MMX 410 DJ mixer. Cueing a track
Select the channel you wish to listen to on the headphone select switch and turn the volume up.
Jan 08, 2010 | ProSound Electronics - Others
I have a Prosound guitar to USB cable but my PC does not recognize it.Can you help?
Solution #1 has misread the question. The question would be better worded: "I have a 1/4" to USB guitar cable manufactured (or marketed) by ProSound ...". This device should be recognised by Windows as a Plug 'n' Play device. There are no drivers to install. If Windows does not recognise the device, it might be a fault with the cable or Plug 'n' Play. If this a Maplin A54HZ cable, there is an LED at the USB end which lights when connected. My A54HZ was recgnised by XP Pro SP3 straight away and self installed.
Nov 18, 2009 | Computers & Internet
67 people viewed this question
 Grubhead
Grubhead
