Question about Air Tools & Compressors
WHERE WILL FIND ALTERNATE OF NR62HAEG REFEREGERENT COMPRESSOR
1995 nissan maxima alternator replacement
1995-98 Models
  1. Disconnect the negative battery terminal.
  2. Remove the splash guard on the right side of the vehicle.
  3. Loosen the alternator belt idler pulley.
  4. Slip the drive belt off the alternator pulley.
  5. Remove the four air conditioning compressor mounting bolts.
  6. Remove the radiator fan and fan shroud.
  7. Move the air conditioning compressor forward.
  8. Disconnect the alternator harness connector.
  9. Remove the alternator mounting bolts, and lower the alternator from the vehicle.
To install:
  1. Hold the alternator in place and install the mounting bolts.
  2. Plug in the alternator harness connector.
  3. Move the air conditioning compressor back into location.
  4. Install the radiator cooling fan and shroud.
  5. Install the air conditioning compressor mounting bolts.
  6. Place the drive belt on the alternator pulley.
  7. Tighten the drive belt to the proper tension with the idler pulley.
  8. Install the splash guard.
  9. Connect the negative battery terminal.
Proper belt tension is important. A belt that is too tight may cause alternator bearing failure; one that is too loose will cause a gradual battery discharge and/or belt slippage, resulting in belt breakage from overheating.
May 31, 2016 | 1995 Nissan Maxima
How to remove the alternator from a 2002 chrysler sebring without discharging the ac
alternator in tight spot,you need to loosen remove brace bolts you need brace with alternator.remove alternator pivot bolt and spacer and adjustment nut and bolt,when you remove alternator you have to angle it out through bracket by the AC COMPRESSOR. YOU DONT HAVE TO DISCONNECT ANY AC LINES OR COMPRESSOR TO REPLACE ALTERNATOR.
Nov 27, 2012 | Cars & Trucks
How do I replace the serpentine belt on a 1999 Kia Sephia?
1.8L Engine
  1. Using a belt tension gauge, measure the drive belt tension and compare with the following specifications:
    1. Alternator belt (new): 86-103 lbs. (383-461 N)
    2. Alternator belt (used): 68-86 lbs. (304-383 N)
    3. A/C compressor and power steering pump belt (new): 110-132 lbs (491-589 N)
    4. A/C compressor and power steering pump belt (used): 95-110 lbs. (422-491 N)
      Fig. Using a tension gauge to measure the alternator belt tension - 1.8L engines (click HERE for zoom)
  2. Using the deflection method, apply moderate pressure (about 22 lbs) halfway between the pulleys, and compare with the following specifications.
    1. Alternator belt (new): 0.31-0.35 in. (8-9mm)
    2. Alternator belt (used): 0.35-0.39 in. (9-10mm)
    3. A/C compressor and power steering pump belt (new): 0.31-0.35 in. (8-9mm)
    4. A/C compressor and power steering pump belt (used): 0.35-0.39 in. (9-10mm)
  3. If the specifications fall outside the ranges given, adjust the belt as follows:
    1. Loosen the alternator mounting bolt and adjusting bolt.
    2. Adjust the alternator to get the specified belt deflection.
    3. Tighten the bolts, then recheck the tension.
      Fig. Adjusting the alternator belt-1.8L engines
Hope helps.
Oct 09, 2011 | 1999 Kia Sephia
How do I replace the serpentine belt?
1.8L Engine
      Fig. Using a tension gauge to measure the alternator belt tension - 1.8L engines (click image for zoom)
Hope helps.
Ho do i change the alternator on a 95 Nissan maximum V6.?not your normal swap out,! looks like i have to take out the radiator.is that so?
No, but you do have to take the fan and shroud off. then you pull the compressor loose and pull forward.
Oct 25, 2010 | 1995 Nissan Maxima
How do I remove the belt that goes between the alternator, A/C compressor and the harmonic balancer?
without knowing what car, this is a general idear. the alternator or a/c compressor will be able to pivot. look for a straight shaft through one, usually close to the motor. on the other side will be a locking nut or bolt located out board of the pivot point,usually going through a bracket and onto the alternator or a/c compressor. if you loosen this nut or bolt the alternator or a/c compressor can swing closer to the engine and the belt should be able to be removed.
Aug 31, 2009 | 2001 Mitsubishi Diamante
I need to replace the alternator on my sisters car and its not here right now and was wondering where the alternator is located so i will know if ill be able to get to it to fix it
if you have the 2.3 liter engine follow these steps...
  1. On models with anti-theft audio system , refer to Technician Safety Information .
  2. Disconnect battery ground cable.
  3. Remove lefthand charge air cooler, then righthand upper seal board, Fig. 3 .
  4. Remove condenser fan assembly.
  5. Disconnect alternator, then alternator electrical connector.
  6. Remove lefthand splash shield.
  7. Remove drive belt.
  8. Remove A/C compressor, then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  9. Remove alternator from under vehicle.
  10. Reverse procedure to install, noting the following:
    1. Torque lefthand splash shield bolts to 70 - 95 in.lb.
    2. Torque condenser fan bolts to 70 - 95 in.lb.
    3. Torque lefthand charge air cooler nuts to 12 - 16 ft.lb.
if you have the 2.5 liter engine then follow these steps....
  1. On models with anti-theft audio system , refer to Technician Safety Information for system deactivation procedure.
  2. Disconnect battery ground cable, then remove electrical harness, Fig. 4 .
  3. Disconnect terminal B wire, then alternator electrical connector.
  4. Remove righthand splash shield.
  5. Remove drive belt.
  6. Remove A/C compressor; then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  7. Remove alternator from under vehicle.
  8. Reverse procedure to install, noting the following:
    1. Torque upper alternator bolt to 12 - 16 ft.lb., then lower alternator bolt to 24 - 33 ft.lb., Fig. 4 .
    2. Torque A/C compressor bolts to 12 - 16 ft.lb.
    3. Torque righthand splash shield bolts to 70 - 95 in.lb.
Aug 04, 2009 | 1995 Mazda Millenia
Toyota Camry 95 V6 XLE Compressor
THE A.C COMPRESSOR BELT ALSO RUNS THE ALTERNATOR.AS OF YET THERE IS NO PULLEY U CAN INSTALL TO BYPASS THE A.C COMPRESSOR.SO YES YOUR A/C COMPRESSOR MUST TURN IN ORDER FOR THE ALTERNATOR BELT TO TURN.CALL AND A COUPLE OF ESTIMATES
Apr 29, 2009 | 1994 Toyota Camry
How do you remove alternator from 1995 Maxima
Hope this helps!
0900c152800760af.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: The large positive lead connection is protected by a rubber boot
0900c152800760b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Make sure the alternator ground wire is also removed
0900c152800760b1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Remove the lower adjustment bolt ...
0900c152800760b2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 4: ... followed by the upper pivot bolt. Make sure you support the alternator
0900c152800760b3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 5: Using a C-clamp to push in the pivot bushing will make installation easier
1995-98 Models
To install:
Apr 08, 2009 | 1995 Nissan Maxima
Air Tools & Compressors Logo
29 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
