Question about Sharp EL-531VB Calculator
Display results exponentially
I want to get the answer in the form of x10
    Scholar:
    New Friend:
  • 74 Answers
Change your settings to scientific notation. To do this press SETUP and choose 0 for FSE and then 1 for SCI.
Posted on Nov 26, 2014
I cant figure out the exponential form for 16
I am not sure what you mean. Even politicians use the term exponential so it has become blurry.
16=2^4 The power function is related to the exponential.
16=1.6*10^1 Scientific notation. Scientific notation is an exponential display format.
Take your pick.
Dec 10, 2013 | Office Equipment & Supplies
For my homework i have to figure out what the exponential form is for 16
Take your pick.
Exponential form for 16
Take your pick.
How to get answer in exponential form in fx-82ES
Press SHIFT MODE 7 then specify the number of digits you want after the decimal point.
May 14, 2012 | Casio Scientific Calculator Fx-82es Plus
How to remove the grad mode from my canon f-710?
Grad is a unit of angle. The angle unit affects only the results that involve trigonometric functions and their inverses. It cannot affect the display of results in exponential format (scientific).
Change the angle unit to degree or radian if you want.Disable the scientific or engineering displays by using FIX or Normal (floating).
May 06, 2012 | Canon F-710 Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
Converting between Forms When working with phasors it is often necessary to convert between rectangular and polar form. To convert from rectangular form to polar form: M = sqrt{A^2 + B^2} f =...
You can switch the display mode for complex numbers by pressing SHIFT MODE down 3 and picking one. This will display the current result in the selected mode.
You can also override the current display mode and specify the format. Add these keystrokes at the end of a calculation: SHIFT 2 then 3 for polar or 4 for rectangular.
Nov 24, 2010 | Casio FX-115ES Scientific Calculator
Step by step ho to Convert Fractions to decimals?
No post is an adequate substitute for reading the manual. Here is the meaning of some of the primary keys.
  1. hyp.: To calculate hyperbolic functions: hyp + sin calculates the hyperbolic sine, hyp + cos calculates the hyperbolic cosine, hyp + tan calculates the hyperbolic tangent (sinh, cosh, tanh)
  2. sin. To calculate the sine of an angle
  3. cos.To calculate the cosine of an angle
  4. tan. To calculate the tangent of an angle
  5. yx : y with raised x, calculates general powers
  6. ln: calculates the natural logarithm (log in base e)
  7. log: calculates the logarithm in base 10
  8. ab/c : used to enter mixed fractions; 13 ab/c 7 ab/c 5 enter the mixed fraction 13 and 7/5
  9. x10 to the X : calculates the exponential function on some calculators. used to enter powers of 10 as in scientific notation; 6.02x10^23 is keyed in as 6.02 EXP 23 (Avogadro's Number of Chemistry and Physics)
  10. (-).: This is the change sign. It negates the value of a number. If a result is positive it makes it negative, and if it is negative it makes positive
  11. deg ' " : used to convert between decimal degrees and degree, minute, second.
  12. rcl : used In conjunction with a memory location, recalls the contents of the memory ( if there is one memory M, extracts what is in M and displays it)
  13. sto: used in conjunction with the name of a memory register, stores a result or an entry in the relevant memory.
  14. M+ adds the content of the display to the constant memory M
Jan 13, 2010 | Casio FX-115ES Scientific Calculator
Whats the exponential form of 135
Frankly, I do not understand what you want.
I will try to guess.
Calculate the exponential of 135
Use the [2ndF][LN] key to access the exponential e^x
[2ndF][e^x] 135 [=] result is 4.263389948 x 10^(58)
or 4.263389948E 58
Represent 135 in scientific notation
135 =1.35 x10^2 or 1.35 E2
Represent 135 in Engineering Notation
135=135E0
If none of the above answers your question, maybe you should state clearly what you want, I am no seer.
Hope it helps.
Oct 26, 2009 | Sharp EL-531VB Calculator
I cant divide simple numbers like 0.16/30 i get crazy numbers like 5.333333333x10-3 how do i fix it?
The numbers are not crazy: The calculator uses the Exponential Format if the number to be displayed is too small. What it means is as follows:
5.33... x10^(-3) = 0.0053333: Notice that the digit before the decimal point is at the third position after the decimal point.
in 5.333..x10^(-4) = 0.0005333 it is at the fourth position after the point.
Use the FIX display format and set the number of decimal digits to be displayed to be 2 o 3 or more depending on your needs. Instructions are on screen capture below.
Hope it helps.
Sep 26, 2009 | Casio FX-300MS Calculator
Sharp EL-531VB Calculator Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
