Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
My bread tin for my synergy breadmaker will not sit in machine correctly
I don't know if I have lost something from the bottom of the bread tin
Bread pan washers have gone on our Kenwood BM250 what do we need to replace it
The pan for your perticular model has no user-serviceable parts. You''ll need to purchase a new bread pan assembly.
Here's more on the subject:
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the words BREAD PAN TIN MOLD to perform an Internet search. Google is best for these types of searches. Google Product Search is even better in some cases.
Example: If you owned the Fredericks Home Bakery model KHB-178 you would want to enter your search as:
FREDERICKS HOME BAKERY KHB178 BREAD PAN TIN MOLD
Hope this helps & Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 25, 2011 | Kitchen Appliances - Others
Hi WE have a Sunbeam Bread Maker , I think its a 5890 model or looks similar. Its approx 8 - 10 yrs old and has performed Very well and baked lots and lots of loaves. It has just failed in that the wheel...
yes, there is a drive belt in the bottom of your machine, if you can take the metal panel off of the bottom of your machine (unplugged of course!!!) you will see the belt and see if it has broken or slipped off .. here is a site that has replacement belts:
http://www.vendio.com/stores/breadmakerguru/category/5890/catId=3449353
Feb 07, 2011 | Sunbeam 5890 ExpressBake Bread Maker
I do not know when to take out the kneading paddle out of the breadman TR555LC. If not taken out, the Kneading paddle will stay in the bread itself after bake.
you leave the kneeding blade inside , i now its a pain but thats how it is when youve baked your bread you turn the tin upside down and tap the loaf out but theres a hole where the needer has been ,,i have looked at every bread machine on the market and there all the same.....
Jan 23, 2011 | Breadman TR555LC Bread Maker
Blade holder attachment
IF YOU MEAN THE BREAD KNEADER IN THE BOTTOM OF YOUR BREAD TIN YOU CAN BUY THIS FROM AMZON FOR £6.05 ALL PARTS CAN BE FOUND THERE GOOD LUCK
Jan 12, 2011 | Kitchen Appliances - Others
The breadmaker screeches when kneediing. any advice?
oil the kneading pin at the bottom of the loaf tin (inside)
Dec 23, 2010 | Black & Decker B1561 Bread Maker
When the blades are inserted do they have to click into place? Mine just sit loosly on the shafts--but do go completely down to the bottom of the shaft---however, the dough is not mixing or rising or...
Most bread machine paddles fit kind of loose so you can get them off for cleaning. Try turning on your machine like you were going to bake a loaf but don't put any ingredients in. Just watch, you won't hurt anything doing this, you are just trying to see if your paddles are turning or not. If they are turning then your problem is something other than the paddles.
Oct 05, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
I have the Black and Decker All-In-One Deluxe Automatic Breadmaker B1600 Series and it's worked well for years. Today I put the ingredients for a loaf in the bread pan and when it started to mix the paddle...
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Apr 21, 2010 | Black & Decker Bread Machine
Westbend breadmaker. Can't get the pan to lock in
I just tried this, its not a great solution, but a solution none the less. I lined the locking mechanism with parchment paper. With a little bit of trial and error I figured out the right amount to add enough stiffness so the bread pan does not flop about. Tin foil might work work as well. This may create a fire hazard so you will have to keep an eye out for the bread maker.
Rich
Dec 13, 2008 | Kitchen Appliances - Others
Kneading blade
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Oct 08, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
