Question about Canon PIXMA iP1300 Printer
What will i do when the orange light flashes 7 times then the green once
  • 1602 Answers
SOURCE: Canon PIXMA iP1000 Printer - don't work
GO ON LINE
CANON PIXMA iP1000 7 FLASHING LIGHTS
ENTER
ROD
Posted on Feb 04, 2009
  • 6 Answers
SOURCE: when i turn my printer on the light flashes green
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Posted on Mar 08, 2009
envision507
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
cene765
  • 787 Answers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Posted on Oct 19, 2009
cene765
  • 787 Answers
SOURCE: Power Lamp Flashes Green and Alarm Lamp Flashes 7 TIMES
Count how many times blinks orange lamp and check this error in this forum.
Posted on Nov 05, 2009
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
3. Release RESUME
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i950 won't print
Starting with printer in off condition holding reume and then power respectively,now press resume twice and and release power button le green light blink until printhead has finished moving
now is the most crucial information that has to be followed
Thanks And Regards
May 12, 2009 | Canon i950 InkJet Photo Printer
Cannon pixma ip1700 not printing
1. Turn off printer
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
GO ON LINE
ENTER
ROD
Feb 04, 2009 | Canon Office Equipment & Supplies
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Canon PIXMA iP1300 Printer Logo
old marine
old marine
