Question about Umax Mirage II Flatbed Scanner
3 lights were flashing, now no lights flashing & not on
Tried to power up the scanner and nothing (no initialization) would happen other than the 3 front lights would flash. Now when I try to turn it on nothing happens and the lights no longer flash.
    Brigadier General:
  • 4,090 Answers
It is always handy to state the brand and the type of connection when referring a fault.
if its USB the check in ctrl panel DEVICE MANAGER if there is a yellow exclamation mark.
same for serial ...against the scanner
if this exclamation is there it means that it does not recognise the scanner and will need to be reinstalled.
check that the serial plug is on firmly, both at scanner and computer, dont just look... undo and reseat on both. Ensure the POWER plug is connected firmly and that it IS switched on.. try something else in that plug and see if it works.
simple things are often overlooked and users thinking technicians are just stupid to ask these questions, but 9/10 it is the simple thing that causes the problem.
Posted on Jun 23, 2009
How do I get my scanner to work?
Test scanner powers up - ie light comes on when first powered. If nothing - check your power supply and replace or repair if necessary.
Test data cables by changing cable or changing data port. If the scanner is USB connection you should see/hear a connection warning. If nothing happens - either your ports aren't active or your scanner i/o port is faulty
Check you have only one installation of the scanner in your scanners and cameras folder. If more than one copy - delete the spares.
Feb 10, 2015 | HP OfficeJet Office Equipment & Supplies
Buick lesabre stalling
run an inline fuel guage in the fuel line with a clear line, look for bubbles, do this witha an inline spark detector, that should tell you wether its fuel or spark shut down, either of these will not give you a code, i have spent many a day on intermittents, sometimes you just have to go back to baasics
Nov 18, 2009 | 1995 Buick LeSabre
All channels locked out on pro-97 model
You've somehow "initialized" it meaning, all of your frequencies have been deleted. You'll have to reprogram all of them.
Initializing is good if you want to wipe out everything & start fresh. It's not good when it happens "accidentally". It's happened to me twice & it's frustrating !!
Oct 14, 2009 | Radio Shack Pro-97 Handheld Scanner
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Umax PowerLook 2100XL Flatbed Scanner won't power up
the light may have gone, change the buls, also have you got your installation cd you may need that just in case it is not found you have to reinstall
Jan 12, 2009 | Umax PowerLook 2100XL Flatbed Scanner
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Won't complete initialization/calibration
Hi...I  have a PowerLook III, and that sounds like the super frustrating problem I used to have...first of all, don't worry about it not being used for awhile...I didn't use mine for 10 years and now it's great...except my Trans adapter problem. Anyway...I am running Mac OSX.4.11...I got a Ratoc SCSI to Firewire adapter from the Lasersoft people..they make the Silverfast scanninng software...and my scanner works great..no more creepy SCSI bus and driver and card issues...I highly recommed one...I hope this helps! Carole
Dec 11, 2006 | Umax PowerLook III Prepress Flatbed...
Umax Mirage II Flatbed Scanner Logo
140 people viewed this question
Top Umax Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
