Question about Elna Sewing Machines
Elna SU needle position lever is very stiff
I try to move the needle position lever and it is almost impossible ...can do it but end up with raw thumb!
  • Tally Girl
    Tally Girl Feb 15, 2015
    check out this solutionhttp://www.fixya.com/support/t2536329-ne... it covers this problem well, White Sewing Centre is the Swiss Elna Guru
  • Elna Master
  • 1,125 Answers
This is probably due to lack of use and just stiffening up of this lever, best thing is to take off the top cover and get some triflow oil into the lever area, then try to work it back and forwards. First though, always set the stitch length and stitch width dials to zero before you try to move the needle dial, this applies to changing the stitch selector too, always turn width and length to zero first to avoid wear on these parts internally.
If you are happy to delve a bit deeper into your machine internally you might want to join the Yahoo group called Elna Heirlooms where other Swiss elna owners share their love and knowledge of these machines, there will be message thread on this issue there for sure.
Posted on Feb 15, 2015
5 Suggested Answers
neona_techie
SOURCE: Needle position wheel is stuck
Remove the top cover. Note where the shaft of the the needle position wheel enters a metal casting under the wheel. Old oil deposits gum up the shaft. Heating this area with a hair dryer usually frees up the shaft. Be careful you don't use too much heat that would melt the plastic wheel. Lubricate the shaft with tri-flow and work it in by turning the wheel while it is warm. If it sticks again after it cools, repeat the process. It may take several hours or days for the tri-flow to penetrate and free the wheel up.
Advice provided by the amazing Ray White at whitesewingcenter.com
Posted on Jul 12, 2009
  • 323 Answers
SOURCE: needle position
this wheel does seize over a period of time.Remove the top cover so that you can see the wheel. It can be unseized by spraying a mixture of 20% ammonia to 80% water under the wheel. Let it sit for 20-30 minutes, spray it again and then turn it with a pair of pliers. Do NOT break it!! use a soft cloth around it if you want to protect the wheel from scratches.
sewman7
Posted on Jun 18, 2008
Tally Girl
  • 1125 Answers
SOURCE: I have a Elna SU
I was going to direct you to the www.arizonaexpressionz.com website which had lots of Elna instruction and service manuals including the SU but today its links seem to be out of action. It may come back to life so worth checking another time.
In the meantime, did your repair shop actually service the machine or just pull the top cover off, put in oil and tell you that's it. There are still Elna trained technicians out there who are familiar with the older Swiss made machines and its probably worth trying to find one if you think the service centre you've visited hasn't actually addressed the issue.
The other option is if you are in the USA, contacting White Sewing Centre and maybe sending it to them to be serviced. LInk is www.whitesewingcenter.com.
Or if you are technically minded yourself, you could join the "Elna Heirloom" group on Yahoo and then ask the other members there for help, there are lots of Elna lovers with models much older than the SU there who lovingly keep their machines running and share their knowledge. Just be clear as to whether yours is a Star Series SU (white with blue top) or Air Electronic SU (if you look on the id plate of the machine there will be a 2 digit code either 62 or 68.
I hope this helps you a little, I'd certainly persist with it if I was you. I just purchased my second SU 2nd hand after buying a new model of another brand 5 years ago and being quite disappointed with its performance, particularly with heavy jobs.
Posted on Aug 07, 2011
Testimonial: "Thank you - I hadn't thought of looking in the Yahoo Groups. You are certainly right about looking for someone who knows the old m/c's !"
SOURCE: My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Posted on Apr 16, 2012
The needle won't pick up bobbin thread on mu Elna Air Electronic SU
Has this just started after a jam up? As it's usually a symptom of timing being out.
However first check needle is in right way, flat shank to the back and threading is correct including the take up lever.
If no joy then mechanic service time
Apr 18, 2014 | Elna Sewing Machines
Zigzag feature is not working
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jan 09, 2014 | Elna Sewing Machines
Stiff wheel
My model list tells me this is the Star Series SU model, white with a blue top. These were made between 1964 and 1978, so getting on for 50 years old. I am assuming that the fly wheel wont turn at all for you, when machines are left for long periods any lubrication internally dries up. You can try to rectify yourself if you are patient, need Tri-flow Oil (preferably with a long neck applicator so you can get into the little spaces), a special lubricant which also contains a solvent, and a hair dryer to add heat. You will need to take off the top cover (two screws) to gain access to the main shaft and needle swing bearing. Also the free arm top plate should be removable with a single screw. Then get into the machine and clean with a small brush any visible lint or gunky build up on shafts, lubricate, then apply heat to the metal parts and wiggle to free up. Expect to spend some time on it, before you'll get things to free up. The needle swing bearing, the arm which holds the needle often seizes up too so straight stitch will work but no zig zag. You might want to join the Yahoo group Elna Heirlooms, lots of Elna lovers there who share their knowledge.
Dec 15, 2013 | Elna Sewing Machines
Needle is moving up and down but it doesn't move forward
if you have a manual, check and see where the feed dog lever is and make sure it's in the up position. when the feed dog is in the down position it's in the darn mode staying in one place,, but when it's in the up position the machine will sew.
here is a link for a manual, if you don't have a manual
http://www.sewingpartsonline.com/instruction-manual-elna-2110.aspx
Jun 12, 2013 | Sewing Machines
Needle position wheel on Elna Super bought in 1969 won't move
I suspect your Super needs some degunking internally, the old dust,, fluff and oil dries up inside and goes hard and this can eventually gum up unused parts. You could take off the top and have a look, usually a couple of screws holding down the top blue cover. Use a cotton bud and denatured alcohol and clean up around the needle centring wheel internally, cleaning and some gentle movement may free it up. Mary, you may also like to join the Elna Heirlooms Yahoo Group, lots of Swiss Elna owners share their love and knowledge for these vintage machines.
Jul 21, 2012 | Elna Sewing Machines
I have a Elna SU - new in the mid-70's and recently took it to an auth. repair place. The needle position wheel is very stiff - almost impossible to move. It is used mainly in conjunction w/the...
Aug 07, 2011 | Elna Sewing Machines
How do you position the needle/ with which lever or dial? location?
Your model doesn't have a specific needle position adjustment. But you could try this - set it to the shell stitch or lingerie stitch on the stitch selector but leave the stitch width setting on zero, this may move the needle to the left most position with any luck.
Other possibility is to put it in a step of the buttonhole sequence, but again leave stitch width on zero and see if this moves the needle bar to the right or left for you.
Feb 07, 2011 | Elna 2007 Mechanical Sewing Machine
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
I have and Elna su sewing machine and i can't get it to zig zag. Please refresh my memory on the settings i should have it on.
Depends on which SU you have, but you need to move the stitch selector to Zig Zag, then set the stitch length to 2.5 and the stitch width to at least 2.
On the earlier models the stitch selector is a wheel inside the flap on the top of the machine, on the air electronics, it is a coloured dial.
If this doesn't help, check if you've inadvertently moved the needle position to the side setting.
Aug 23, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
