Question about Electrical Supplies
Honda 3000 generator leaking fuel near carburetor.
4 Suggested Answers
ROMOAS
  • 97 Answers
SOURCE: does the honda 3000 generator
there is a screen in the tank at the shutoff valve best bet it to remove it and tear it out and use a in line filter where it is easier to replace
Posted on Aug 31, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Generator runs for about 10
It appears you have eliminated all of the fuel related issues. That would leave the generatoor safety circuits as a possible reason for the unit shutting down.
The Low Oil Level Sensor is the major reason that generators shut down when your sure there is not a fuel supply problem. Make sure the unit is fully servied with OIL. If the problem persists disconnect ONE wire from the low oil level sensor and see if the problem persists. If you still have the problem inspect the black or green wire from the Start run switch all the way to the Air shroud on the engine looking for signs of chaffing.
If you can not find anything then you will have to re-focus your attention on the fuel system once again. If you have a solenoid on the base of the carb.. the solenoid can be WEAK and stop remaining open once hot. This will cause the engine to lean out and die.
You should also check fuel flow to the carb. The flow should fill a spary paint can lid in under 10 seconds to the point your worried about it overflowing. Most honda engines have a metal sediment bowl under the fuel selector. Remove the sediment bowl and dump the contents. Check fuel flow again.
- Carb. With the float bowl removed fuel selector ON check fuel flow again by holding a spray paint can lid under the float. It must fill up in about 10 seconds to the point your worried about over-filling the lid. If you do not have a good flow rate here the float needle float needle rubber seat and the fuel manifold are the prime suspects.
I know this generator has the Honda GX270 engine. Some have solenoids (Item 49 this link)
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE,%20JPN,%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CARBURETOR%20(2)/parts.html
^- No details!
Honda engines by model and VIN can be found here:
http://www.boats.net/parts/search/Honda/Engine/0/parts.html
At this time I think the low oil level sensor (sending uint) may be the culprit causing your problem.
Item 2 this link:
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE%2C%20JPN%2C%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CYLINDER/parts.html
Thanks for choosing FixYa,
Kelly
Posted on Sep 16, 2011
jerardi
  • 14162 Answers
SOURCE: my Honda 3000 electric electric start generator / inverter is leaking gas
problem with my generator Honda EU3000
Generator Engine Leaks Gas
AND YOU MIGHT CONSIDER READING THE LINK BELOW AS WELL FOR ADVISE, TIPS AND TRICK.
About those generators Tips and tactics to keep it running through the...
Posted on Jul 23, 2015
My Honda generator 3000 / inverter has a horrible gas leak what could it be
Try the tube that runs between the fuel tank and the carburetor. I have seen them crack since the tank is stationary and the engine is on rubber motor mounts. That line is in constant motion.
Jul 23, 2015 | Honda Electrical Supplies
MY HONDA 3000 IS GENERATOR KEEPS STALLING OUT, BUT IT ALWAYS STARTS UP IMMEDIATELY FOR ME, COULD IT BE OVERHEATING?
No, as with most small equipment engines, the culprit is the carburetor. You'll need to soak it in carb cleaner overnight in a sea;ed container and install the rebuilt kit for it.
Jun 16, 2015 | Honda 3000 Watt Portable Generator
My troy built 7000 generator is leaking gas. I replaced a gasket but it is still leaking. HELP!!!
With generators sitting long term not use carburetors tend to get gummed and need a good cleaning and depending how bad this gumming and corrosion is either a carburetor repair kit or carburetor will be needed.
It best to use a good fuel stabilizer in the fuel for short term storage and for long term to shut the fuel flow off and run the generator until it uses up the fuel in the carburetor.
Jan 01, 2015 | Electrical Supplies
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Oct 19, 2013 | Electrical Supplies
My Honda generator EG550 wont start. I have a spark and the fuel appears to flow, although when I remove the spark plug there is no smell or sign of petrol. Any ideas what to check next? Cheers Del
check your needle seat its stuck. clean and flush your fuel sys in tire sys carburetor to. new fuel and stabilize the fuel. try it but keep a look out for fuel leaking from the carburetor after Wards. if so you'll have to over haul the carburetor
Oct 11, 2009 | Electrical Supplies
My 13hp honda generator won't run.I have cleaned the fuel bowl,new plug,air cleaner,evan removed air cleaner assembly off side of engine,I can get it to start,after much cranking,but it will not run for...
You cleaned the fuel bowl? Was there any dirt, etc, in it? How does the fuel line look? How about the bottom of the fuel tank? How old is the fuel?
From your description, it 'sounds' like a fuel system problem. If it's a Honda EU3000is, it has Electronic Ignition, and electronic ignition usually just goes out all the way, not slowly.
The fuel line is small, and easily obstructed. Does fuel flow when the fuel line is removed from the carburetor? After the generator starts, runs, then dies, remove the float bowl. How much gas is present?
Observe the float. See if it's in good repair.
Check the float needle. See if the rubber (Neoprene) tip is squished, or is still in good shape.
Could be that when gas fills the float bowl, the float raises, then gets stuck in the up position, cutting off the gas flow.
Aug 31, 2009 | Honda 3000 Watt Portable Generator
Electrical Supplies Logo
85 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
