Question about Britannia SI10T6L Dual Fuel (Electric and Gas) Kitchen Range
Britannia S1-15GEB-BR,Fan setting on right hand electric oven is not heating up at all.Yo
U can hear the fan humming.I have made sure the red hand is displayed on the clock.All other cooking options are working except for the fan mode,thanks
3 Suggested Answers
  • 8 Answers
SOURCE: brittania SI/9TB/SS fan in main ove glows red hot
There is a fault on you oven please ring Britannia for a service call on 01253471111 option 3. They can also supply a new oven seal
Posted on Jul 20, 2009
richroth
  • 9472 Answers
SOURCE: I have a britannia dual fuel cooker. My main oven
Sorry, I am not familiar with that model.
Posted on Oct 24, 2011
Goodman air handler ARUF036-00A-1A does not blow air in heating or cooling mode only hums/buzzes, what could it be?
Looking at the wall thermostat, you will see the fan switch that has two settings: fan auto, fan on.
You will need to place the fan switch in the fan on position for testing purposes.
This will make the indoor fan run continuosly, and never cycle off.
In the fan auto position, the fan will turn off when the thermostat temperature setting has been satisfied.
Remove the air handler access panel.
Is the air handler fan operating?
If the fan isn't working see if you can listen closely if it is humming, or can touch the motor to see if it is hot.
If it is humming and has a bad capacitor, you can tell this without having an electrical tester by spinning the fan wheel by hand.
Be very careful... making sure your hand won't get cut by the fan wheel spinning when it starts up.
If the fan spins and picks up full speed, replace the defective fan capacitor.
It is the shiny silver metallic cylindrical object with electrical wires attached to it.
Make sure you write down where those wires attach and turn the power off before removal as they carry 240 volts to the fan motor.
If you find that the fan wheel doesn't turn freely when you try to spin it by hand, the bearings have seized and you will need to find another fan motor of the same size, shaft length , speed , and horsepower to replace the defective motor.
Keep in mind that a humming sound in the air handler COULD be from the transformer instead of the fan motor.
The transformer is a black cube shaped device with electrical wires attached to it.
If the 24 volt transformer goes bad, your thermostat will not function and nothing will come on.
Dec 01, 2014 | Goodman Heating & Cooling
Britannia si-12t76x2
If your oven has no heat you'll need a new oven element, if your oven is cooking food too quickly/burning at the back then you'll need a new fan, if the oven is burning everything you'll need a new thermostat, if the oven isn't working at all check that the clock/timer hasn't been set for auto ie make sure it is on 'manual cooking'
Jun 16, 2012 | Britannia SI10T6L Dual Fuel (Electric and...
After oven turned on for normal baking it starts to hum rather than typical noise from exhaust fan.
If you're not hearing the fan turn at its normal speed, it is possible that your fan motor has become stalled. AC motors will often hum or buzz when they can no longer turn but still have power applied to them. This could be due to bad bearings, or a blockage of some sort. It's probably not easy to get to, but if you can hand check the fan it should spin quite freely. Be sure to unplug the unit before messing with the insides, or shut of its circuit breaker if it's a built-in unit.
Dec 24, 2010 | Dacor ECS130 Epicure Electric Single Oven
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Britannia fan oven fan makes rumbling noise when operating. How do you remove fan? What is probable cause of noise? This has just started. Model is Britannia SI-9T.
*****************TURN OVEN OFF AT MAINS OR JUST TURN ALL ELECTRICS OFF ****************NOW.........hi the fan blade nut is anti clock undo... take fan off... you will see three screws undo... go to rear of oven remove panel..... the fan will come away in your hands... disconnect wires ... reverse action needed to put back together....
Dec 30, 2009 | Ovens
CREDA OVEN FAN NOT WORKING OVEN BARELY HEATING
As a first port of call, you can remove the fan by removing the inner back panel (4 screws) and taking the fan blade off (anti clockwise screw) The drop the fan out through the back of the cooker. If you apply WD40 to the two bearings you may get the fan going again. Otherwise you'll have to replace it.
Sep 29, 2009 | Creda C361E Electric Kitchen Range
Need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Jun 08, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Brittania SI/9TB/SS fan in main ove glows red hot
May 07, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Britannia SI10T6L Dual Fuel (Electric and Gas) Kitchen Range Logo
32 people viewed this question
Top Britannia Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
