Question about Building Materials
ACI 303R-12 guide to cast-in-place architectural concrete practice
3 Suggested Answers
  • 73 Answers
SOURCE: Punch Home Design Architectural series 3000 ver 12
The textures going to the sky / grass is a classical issue of a videocard problem
Try to follow these steps
1 - Go to the website of your video card manufacturer (it can be found using any search engine and the manufacturer's name and the card model). Look for downloads, and see if you have the latest version of driver software for your model of video card (you can find your current driver's version at Video Settings->Advanced->Adapter). If there is a newer one for your card and the operating system, you are running, download and install it following the manufacturer's directions.
2 - Click on Start->Run and type in "dxdiag", and click Run. The DirectX diagnostic will run, and tell you what version of DirectX you are currently using. Go out to www.microsoft.com/directx, and see what version is current. If your version is not current, read the install instructions, the system requirements, and the FAQ. It is recommended that you download the latest version and install it.
3 - Try to slowdwn the videpcard accelerations: To slow down accelerations--> click on an empty part of the windows Desktop, click on Settings->Advanced->Troubleshoot. Back the accelerations slider to the left, one level each time and see if the problem dissapears
Hope this helps
Posted on Oct 30, 2008
SOURCE: I dropped my Paslode F350S framing nailer on
You will have to take it to your nearest paslode repair agent(check for your nearest repairer on the paslode web site). It sound like you have damaged cylinder or comb. chamber. the orange casing is just that a casing to hold the internals together. The gas framing gun is just like your car motor. Fuel(gas cell),spark(spark plug), motor(piston moving up and down a cylider) and filter/air( fan to move air around evenly and filter for tool to breath)
Posted on Jan 15, 2010
How many Categories of Shot Blasting Machines?
There are five categories of China shot blasting machines: road surface shot blasting machines, tumble shot blasting machines, hook type shot blasting machines, table shot blasting machines, internal steel tube shot blasting machines.
Here's a detailed introduction of the characteristics of various kinds of shot blasting machines.
1. Road surface shot blasting machines
Shot blasting machines for road surface are mainly used to solve the defects of the concrete surface treatment. It can remove laitance and impurities of concrete surfaces at one time, and can have the coarsen treatment of the concrete surface, which brings the uniform roughness of surface. This greatly improves the adhesive strength of waterproof layers and concrete base layers, so that the waterproof layer and the bridge deck can be combined better and the crack of the concrete can be fully exposed at the same time, which is a prevention solution. Automatic reverse blowing dust collectors can clean each filter element through air blew back by the compressor at regular intervals. Then, it will be cleaned through the airflow of the assorted cleaner inside the machine. The abrasive material and the cleaned impurity will be recycled respectively, and the abrasive material can be reused. Each shot blasting machine is equipped with a dust collector so that the construction can be dust-free and pollution-free, which can both improve efficiency and protect the environment.
Advantages:
Shot blasting machines for road surface can be used in the surface treatment of the waterproof base of concrete bridges, the surface coarsen treatment of the pavement overlay, cleaning of the sign line of road, bridge and the steel box girder, improvements of anti-slide performance. Also, it can greatly improve the roughness and texture depth. The uniform roughness will not destroy the original surface structure and integrity. The entire process of construction is dust-free and impurities are completely recycled.
2. Tumble shot blasting machines
Tumble shot blasting machines are is applied for surface cleaning and strengthening of large and medium sized production parts. When the parts to be cleaned is less than 200kg, this machine can be used alone or used as a supporting facility. Applied ranges: die castings, precision castings, the cleaning of precision forgings, mass finishing, removing heat treatment parts, castings, surface oxidation of castings, and intensification of spring, rust removal and pretreatment of fasteners.
Advantages:
Tumble shot blasting machines can be applied for various productions such as large and medium-sized workpieces, rust cleaning or shot blasting of the surface. The workpieces to be cleaned usually are the main parts and heat treatment parts with weight of less than 150kg. The machine can be used alone or used as a supporting facility. It is suitable for the cleaning, rust removal, scale removal and surface strengthening of small castings, forgings, stamping parts, gears, springs and other parts, especially of fragile parts.
3. Hook type shot blasting machines
As the standard mode of shot blasting machines, the maximum carrying capacity of the hook type shot blasting machine is 10000 kg. A hook type shot blasting machine has very high efficiency and good flexibility. It is an ideal cleaning and strengthening facility, which is mainly used for surface treatment of various media, large castings, forgings, weldments, and heat treatment parts, including fragile and irregularly shaped workpieces.
Advantages:
With the advantages of large shot blasting, high cleaning efficiency, large space, compact structures and no special requirements on the shape and structure of the cleaning piece, a hook shot blasting machine can serve several purposes. It is applied for sand cleaning, rust removal, scale removal and surface reinforcement of the castings and forgings less than 15kg of various industries. This machine is equipped with a special set of dust device, so the place of installation is free from the ventilation pipe workshop and it has good sanitary conditions.
4. Table shot blasting machines
The table shot blasting machine is mainly used for volume surface cleaning of small and medium sized workpieces. It is suitable for the engine connecting rod, gear, diaphragm spring , etc. It is widely used in the casting and automobile manufacturing industries. It has several characteristics of high production efficiency, good sealing performance, compact structure, convenient loading and unloading parts, high technical content, etc.
Advantages:
The table shot blasting machine is mainly used for the removal of surfaces' sand, rust, oxide skin, dirt, etc., which can restore the surface color of the metal workpiece, eliminate the internal stress, improve the anti-fatigue performance, increase the film adhesion, and ultimately achieve the goal of improving the surface and internal quality.
5. Internal and External steel tube shot blasting machines
An internal and external steel tube shot blasting machine is a new type of net wall shot blast cleaning machine combined with the shot blasting technology to clean the inner wall of the cylinder.
It uses compressed air as its power and utilizes the kinetic energy of accelerating projectile to shoot the cylinder wall. When the cylinder located in the gun room, the gun will automatically insert into the respective bottle and the spray gun will move up and down in the cavity. Then it will complete the full range of cleaning. Inside and outside wall shot blasting machine is the selected type of the cylinder industry.
Advantages:
An internal and external steel tube shot blasting machine is mainly used for architecture, bridge and other industries. It is used for rust removal of the large I-shaped steel, H beam and surface. It has advantages of large shot blasting, high efficiency, rapid blade replacement, overall replacement performance and easy maintenance. Shot Blasting Machine Manufacturer China Shot Blast Machine
Aug 04, 2017 | Heavy Machinery
Leaking sewer pipe
Depending on how many pipes you have connected in the run from the toilet to the concrete pipe, I would replace all of it with plastic pipe and a new soil pipe if I could find one, if not put the plastic in the soil pipe and pour a concrete patch to fix the hole. Without seeing what you have there, it is hard to say for sure. But cast iron is not used much these days and a job to fix, cut, seal, repair, most are replaced. Hope this helps.
Jun 01, 2010 | American Standard 2860.334 Enfield Two...
How do you cast it? I kept getting tangled...the ...
Put thumb on spool, flick into free spool. look at spot you want to cast too. Cast SMOOTHLY taking thumb off as you get to about 45* to front. *IMPORTANT8 THUMB ON SPOOL THE INSTANT THE TERMINAL END OF LINE HITS WATER!!!!!!!
May 19, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Have a new Daiwa Exceler 100H reel with no paperwork, instructions or feature description. Can you help?
What do you want to know? How to set it up for first time?
1. Spool on some line (start w/mono is not familiar w/bait casters)
2. Installl reel on a rod
3. Set the mag brake to 0
4. Tighten the Cast control nut (next to the star shaped drag control) so it's tightened all the way (don't go crazy and use a lot of force, just set it to the tightest position)
5. Tie on a 3/8 - 1/2 Oz weight or lure - Lure/weight should NOT move at all when you let it go
6. SLOWLY loosen the Cast-control nut (very slowly) until the lure/weight drops slowly about 1/2 turn of the spool
7. Set the Magnetic brake to 5
8. Go practice casting and adjust cast-control and mag brake as needed until you can go without a birdsnest, and you don't ahfve to use all the much thumb control to stop the spool at the end of the cast
9. Practice, practice, practice...
This is what I got from a Daiwa Rep at the Eastern Fishing Expo this weekend in Worcester, Ma and I'll be doing exactly these steps once it warns up enough to go our and play with the new reel and rod (Quantum Energy PT Med/Hvy (6'6").
Peace,
Shepp
Jan 12, 2010 | Boating
I dropped my Paslode F350S framing nailer on concrete and it has a pin hole air leak in the outer casting. Where can I get a replacement outer shell? Also can a pin hole air leak be repaired? The nailer is...
Dec 22, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I just recently purchased a shakespear sigma baitcast reel, and I can't cast the thing without backlashing it
Baitcast reels are very frustrating to some people. There should be a dial on the side which controls a magnet that keeps it from backlashing make small adjustment and cast also use your thumb to aid in controlling the spool.Then practice practice practice.
Sep 06, 2009 | Sport & Outdoor - Others
Use of a Sait Cut abraise wheel to cut PVC Pipe
I worked at a tool rental business while going to college and became familiar with OSHA requirements as it pertains to construction. There is an old saying that if you follow the rule-book by the letter things will quickly come to a grinding halt. I checked on OSHA web site and could not find anything on you question. I recall that using the correct blade only results in a cleaner cut, however there is the possibility that the pvc material can load-up on the blade and cause jambing. An inspection of the blade will answer this. More important is that all safety items are in place like the blade guard and that all workers in the vicinity of the saw are wearing eye protection. We used Norton brand abrasive blades and the following is their guide. APPLICATION GUIDE:
Concrete:
For concrete/masonry - silicon carbide specification for brick, block, concrete, and other masonry materials.
Metal: For metal/steel - aluminum oxide specification for mild steel, stainless, and metal decking.
Asphalt: For use when cutting mostly asphalt.
Asphalt / Green Concrete: For asphalt and green concrete - silicon carbide in coarse grit range. For high performance, hot pressed wheels provide significantly longer life.
Ductile: For ductile iron and cast iron pipe - formulated with a special blend of silicon carbide (for cutting) and aluminum oxide (for long life). This specification is also suitable for cutting PVC.
Hope this helps, enjoy
Dec 09, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Building Materials Logo
161 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
