Question about Audiovox VOD102 Car DVD Player
We have a 7" audiovox flip down screen. The hinge on back cover broke. Can I get a replacement/
  • 365 Answers
No, sorry...stop by a local car stereo shop and ask them for a solution...could be a cheap "gerry-rig" job under $50
Good Luck
Posted on Jun 22, 2009
I have great sound on my Audiovox portable dvd player but no picture. Can you help?
  • Check that the A/V IN/OUT Switch on the side of the player is set to the OUT position.
  • Check the small switch near the hinge at the back of the unit, if one is installed there. It turns off the LCD screen when the panel is closed. This switch sometimes sticks in the down position and the screen remains off. When the screen is opened, the switch is supposed to pop up. If it is still in the down position, try to free it with the ends of a toothpick or paper clip.
  • If both switches are correctly set and the screen remains blank, the unit should be sent to Audiovox for service.
May 16, 2011 | Audiovox D1708 Portable DVD Player
Tip
How to disassemble a nokia n95
First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.<br />Now move the slider up and remove the two screws at the top of the phone.<br />Run your fingernail along the edge of the join of the front cover to unclip it.<br />You should now have the front cover removed. The keypad should be loose as well.<br />Flip the keypad part back to access the ribbon which connects the LCD to the phone.<br />To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.<br />Pull the LCD in the direction like you are sliding the screen up.<br />You can now replace the screen.<br />Reverse the whole procedure for reassembly.
on Jan 10, 2011 | Nokia N95 Cellular Phone
Hello sir i haw n95 no light in disply
If you are not having light on your nokia n95, then it means the florescent tube of your is bad, the solution is for you to replace the screen of the phone. To replace the screen of the phone, follow the steps below:
  1. First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.
  2. Now move the slider up and remove the two screws at the top of the phone,
  3. Run your fingernail along the edge of the join of the front cover to unclip it.
  4. You should now have the front cover removed. The keypad should be loose as well.
  5. Flip the keypad part back to access the ribbon which connects the LCD to the phone.
  6. To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.
  7. Pull the LCD in the direction like you are sliding the screen up.
  8. Your phone should look like below and you can replace the LCD.
  9. Reverse the whole procedure for reassembly.
If you are not familiar with such technical activity, i will suggest you ask a friend who is familiar with it to assist you in carrying out the job.
Hope this information helped.
Jan 09, 2011 | Cell Phones
Lcd screen disconnected?
to get to the screen of your phone, follow the process below:
Pull the LCD in the direction shown.
Take care
Oct 12, 2010 | Nokia N95 Cellular Phone
LG VX5300 Flip Phone broke in half.
Your phone can work again, all you need to do is to get the flexi cable and fix it back in place.
It is not expensive.
It is about $15.
To fix this, these are the processes to follow;
  1. Get the appropriate screwdriver,
  2. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  3. Next remove the 2 rubber stoppers and unscrew the aerial.
  4. Remove the 6 screws,
  5. Next remove the 2 rubber stoppers & screws above the main screen,
  6. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  7. Unclip the ribbon,
  8. After removing the ribbon cable, carefully lift the metal part that is beneath the phone. Another ribbon will be attached which should be carefully removed.
  9. Take the circuit board & keypad out and you'll be left with what's below it.
  10. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  11. To open the top half of the phone and get to the screen, run your fingernail between where the two parts of the housing meets,
  12. Try to open up the top part by splitting it open with a credit card,
  13. replace the ribbon and,
  14. Reverse the procedure for reassembly and it's finished.
Take care
Jun 21, 2010 | LG VX5300 Cellular Phone
I am looking for replace parts for DVD flip screen for Ford 2004
use velcro to hold it close it will work but not look great
Oct 26, 2009 | 2003 Lincoln Navigator
Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
I have a Motorola V365 phone. The phone was dropped several months back and broke a portion of the cover that holds the hinge in place on the flip portion. The phone has continued to work fine. This past...
Your best bet is to take it to your cell phone service provider to see if they can retrieve that information. If you are on Verizon, they offer the backup assistant to retain information like this and to be able to transfer that information onto other replacement phones. The memory in your phone is probably OK and that is where your contact information is located so they should be able to recover that. The small ribbon cable that broke provides power and data to the display and should not affect your stored data. If that cable has a short across it, it may impact your ability to get your data on your own.. Good Luck
Regards,
Rick
Dec 07, 2008 | Motorola Mobility V365 Cellular Phone
Top flip section of phone broken,
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Aug 14, 2008 | Samsung SCH-u740 Cellular Phone
Image upside down on my Audiovox VE1020
Check the screen position switch, they sometimes get fouled especially if installed in a kitchen.
Apr 07, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Audiovox VOD102 Car DVD Player Logo
127 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
