What is the minimum wattage speakers for nad c 340 amp?
  • 3,368 Answers
Since there is no minimum output there is no minimum wattage rating.
Posted on Nov 04, 2014
4 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: How to hock up two 8 ohms speakers to bridged 90 watt Nad 209Amp?
Depends on output requirement (in ohms) on the amp. Any further questions, don't hesitate to ask. If this is helpful, please post as such. TY
Posted on Jan 24, 2009
  • 49 Answers
SOURCE: what is the maximum speaker wattage for a NAD c340
The specs say 2x50W into 8 ohms. I could not located the 4 ohm specs, but it is logical to assume that you can run 2x100W into 4 ohms.
The back panel seems to imply that 4 ohms is a limit for speakers.
So any speaker over 100W capability should be fine, either 4 ohms or 8 ohms.
Posted on Oct 31, 2009
  • 185 Answers
SOURCE: my NAD C350 amp only powers one speaker channel
over heating is a sign of overloading or over bias
Posted on May 27, 2010
Having trouble under standing rms with speakers. Some speakers rms is per speaker and other are for both speakers.I am looking for soundstream speakers that would be 150 rms per speaker. Thanks
rms is a method of measuring power (wattage) delivered from an amp to a speaker. In almost every case, wattage capacity of speakers is quoted PER SPEAKER. Likewise wattage output is quoted per amp output channel. Assuming a you plan on a single speaker on each output channel of your amp, you should be in good shape if your speaker wattage capacity equals or exceeds your amp's output rating. I've never seen speakers rated as wattage per pair.
(rms is the dominant way of measuring average watts of an ac sine wave signal)
Apr 23, 2017 | Car Audio & Video
Need a good 500 watt cd player not sure what to buy
Before you go off on a wattage hunt you should learn what that means.
Search the web for subjects such as "amplifier wattage vs speaker wattage" for starts.
Don't buy into what manuafacturers CLAIM for wattage if it ADDS all the channels together and FAILS to specify a bandwidth and an acceptably low distortion figure. REPUTABLE makers specify watts per channel, all channels driven at no more than X distortion (typically well under .1%) and, at minimum, across the audio bandwidth or 20Hz - 20kHz.
Any garbage cheapo amp (meaning most shelf systems or all-in-one packages) can put out a lot of dirty power which will strain THEM and possibly kill your speakers. CLEAN POWER is what you want.
Dosome reading and search the web for whatever you are considering, and add the word 'scam' to the search. Get opinions from actual owners. There are a lot of unscrupulous people out there selling garbage to people on the streets.
Aug 22, 2011 | JVC HXC6 500-Watt Stereo System with 5-CD...
Maytag MDB7100AWW Dishwasher how many minimum amps is needed
to find out the amps needed you need to take the wattage that is listed on the information tag on the door of the dishwasher. Take the wattage number and multiply that number by 1000. Take the figure and divide it by the a/c current used to run the dishwasher this total is the minimum amps need for the proper operation of the dishwasher.
Example 35 watts X 1000 = 35000 divided by power supplied say 120 volts 29.1 amps or 30 amps
Hope this helped
Dave
Jan 18, 2010 | Maytag MDB7100AWB Dishwasher
What is the maximum speaker wattage for a NAD c340 integrated amplifier?
Oct 30, 2009 | NAD C340 Integrated Amplifier
Need manual for ra 840bx4 & wattage output when remote speakers?
Lets try the simple stuff first. This whole problem could be caused by a dirty switch contact. Pick up some electronics cleaner from a local electronics shop and spray the switch (from the inside of the unit). Work the switch on/off a number of times then respray one more time. That should clean out any dirt that is there. Try the unit again and hopefully the problem is resolved. If not, then the switch itself may need to be replaced. When you get the cleaner, get one that contains a lubricant as well. This will help to prevent the problem from coming back again.
Dan
Jun 20, 2009 | Rotel Audio Players & Recorders
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Nad 214 amp
problem is- intermittent speaker relay. You can cleaned contacts or better upgrade relay to better one (sealed)  Dariusz
Jan 03, 2008 | NAD 712
 Grubhead
Grubhead
