Why won't my Hot point Aquarius WML 760 spin?
The spin cycle doesn't kick in unless there's only about 2 things in the machine!
the dr
  • 447 Answers
SOURCE: Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Posted on Jan 15, 2008
SOURCE: washing machine hot point aquarius wms38
remove the panel at the lower rear of the machine you will then see the motor there are two 13mm head bolts remove both of these, hold the motor and push it toward the front of the machine this will disengage it and it can then be lowered and removed from the rear of the machine remembering to disconnect the white multiconnector and the earth wire. Job done refitting is the reverse of removal.
Posted on Mar 07, 2008
barkencoa
  • 3463 Answers
SOURCE: Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
SOURCE: Noisy when spinning
bearing gone cheaper to buy a new one
Posted on Jan 23, 2010
  • 51 Answers
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF100 Spin Hot
use a label maker they cost 15 to 20 and the labels last forever.
there are ways to stencil them on but they will come off unless you use plastic paint.
Apr 02, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
