Question about Samsung Refrigerators
Red light has come up on my samsung rsh1dbbp but it hasn't been hooked up 2 the water yet
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Samsung scx6555n showing error #31-007
I have encountered this problem twice on the same machine with different imaging units. I haven't received an answer from Samsung (presumably they will fix with a firmware update, their solution to everything) but the message and the red light can be cleared by powering down, reseating the the IU and powering back up. The good news is the user can still use the machine, even with the code.
Sep 13, 2012 | Samsung SAMSUNG SCX6555N LASER...
Samsung RSH1DBBP Digital Display problem
The display panel has damaged. It has to be replaced by same type and number. There is no repair to it. OK.
Feb 01, 2012 | Samsung RSH1DBBP (19.1 cu. ft.) Side by...
My 12inch speakers work in my house but when I hook them back up to my truck they dont work . My amp used to have a red light on it but now it doesnt work i bought a new amp and speakers and still nothing...
Could be a number of things. Check all the fuses (the power wire, the amp). Make sure your ground wire hasn't worked loose. Make sure your remote wire hasn't worked loose either (sometimes vibration causes loose crimped wires to come out behind the head unit). Happy Hunting
Aug 20, 2011 | Car Audio & Video
Samsung model rsh1dbbp: fridge running at 19 degees. have cleared ice build up in lower left hand side. freeer and water ok. no ice build up in freezer
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
Apr 01, 2011 | Refrigerators
I have a Samsung rsh1dbbp fridge/freezer, the change filter light has come up, but the instructions are not clear I do not know where to install the new filter, could someone help me?
The filter is located behind the fridge. This is a self contained filter cartridge that is replaced as a unit. Online they sell for about £4. Pull the fridge out completely and you will probably see the filter cartridge clipped to the wall. The filter is about 10 inches long and about 2 inch diameter. Note the flow direction marked on the new cartridge, and remember to turn off the water supply before disconnecting to inlet and outlet pipes from the filter . Hope this helps
Jan 03, 2011 | Refrigerators
Kenmore
sounds like your freezer isn't freezing lift up the wire arm on the ice maker to shut it off then put your finger where the ice cubes should be and if the water isn't frozen you may have a cooling problem listen to see if you hear the freezer fan running then look at the bottom of the freezer at the back wall where the vents are and see if they are blocked with frost and reply to me
Dec 31, 2007 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
