Question about Fisher and Paykel Refrigerators
OK I have the RF610A fridge on top and freezer below in French door arrangement. Fridge not cold, freezer appears fine.
I have the RF610A fridge on top and freezer below in French door arrangement. Fridge NOT cold, freezer appears fine. Already replaced both fridge sensor and evaporator sensors but still have error F08 and spanner symbol up. Noticed evaporator coil had ice all over it when changing sensor- this evaporated whilst unit was off. Both evaporater and fridge cooling fans are working but I do not hear compressor working although it must be if freezer is cold?? What is next step please?
Benimur
  • 6966 Answers
SOURCE: Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
rpbuice
  • 161 Answers
SOURCE: Freezer gets cold, Refrigerator Hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You can't see the door but, you should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system which consist of the defrost timer, heater, and thermo disc.
Also, If you replaced the evaporator fan then you got a good look at the cooling coils. Look at these coils while it is running. There should be a light coat of frost on all the coils. If this frost line is only 3/4 or 1/2 or any amount less than full coverage of the coils then the system has a coolant leak.
Directly under these coils is the drain pan and drain hole in the middle. This area should be clear of any ice or debris.
Posted on Dec 25, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Compressor not running, Fridge/Freezer not
Unplug refrigerator pull away from wall. Remove cover over compressor and feel top of compressor to see if overheating or trying to start. If too hot to hold hand on top leave unplugged until we locate the problem. This could be capacitor, start relay, overload, motherboard. This can Be fixed but we need to eliminate cause before replacing any parts. Sea Breeze
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: Bottom Freezer Profile fridge does
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 07, 2010
OK I have the RF610A fridge on top and freezer below in french door arrangement.
Have you checked the fridge thermostat? If the thermostat is ok then you should trace the volts which operate the valve which connects the compressor to the fridge evaporator coils. If the valve is getting volts then the valve is faulty. If not fault lies with control circuitry.
May 08, 2014 | Fisher and Paykel Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
Fridge not cooling freezer top mount ok
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
88dt
Apr 27, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refridgerator not cold but freezer is freezing fine.
This model uses the cold air from the freezer, defrost complet unit for 24hrs, turn back on and it should work ok. Regards Advisor
Aug 19, 2007 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
32 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
