Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
Fender deluxe reverb problems - Fender Hot Rod Deluxe Guitar Combo Amplifier
  • 5603 Answers
SOURCE: The red and white connections going to the Reverb
If you touch each wire, the one that receives the output of the tank should hum. Quick and dirty test.
Posted on Mar 13, 2010
Testimonial: "Very helpful Thank you."
  • 57 Answers
SOURCE: Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Posted on Apr 24, 2010
  • 5603 Answers
SOURCE: like johbow I also have a frnder hotrod deluxe amp
The TL072 is shown having a must better distortion figure than the TL082.
DigiKey.com has them 50 cents. I would NOT substutute the 82 for the 72 in this case.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=497-2201-5-ND
Posted on May 28, 2010
Testimonial: "fredy bless you sir,i have been searching for substitutes online w/out much luck.I respect your opinion and will just order the tl072.Guess I was just looking for a fast fix.Thank you for sharing your time,expertise and speedie response."
  • 1575 Answers
SOURCE: need a 1978 Fender Deluxe Reverb manual
Whats the model number?But still,the link below gets you to the full list of Fender available model manuals.Click on selection to download.
www.fender.com/support/articles.php?section=downloads&category=product-manuals
Hope this helps.Thanks!
Posted on Jan 07, 2012
guitarmanjoe
  • 336 Answers
SOURCE: My Fender Hot Rod Deville
Make sure the in and out is correct on the reverb chamber., if someone else disconnected it at any time it could be plugged in backwards and act just like that.
Posted on Mar 08, 2013
I have a '93 Fender Blues deluxe tweed and don't seem to have any reverb, am I missing something?
Check the connection to the reverb tank (rectangular box usually sitting on the bottom of the amp). There are a pair wires that connect it to the amp. If wires are connected, and the reverb is not working, you may need to replace the reverb tank.
Oct 16, 2016 | Fender Music
Sometimes the reverb works, then next day it dont.i have a 1999fender hot rod deluxe
Fender Amplifiers are notorious for their reliability issues.However, I'm sure that amp will sound sweet once you get everything working again!
The problem is likely your "tank". The tank contains the springs which create reverb as the guitar's signal is sent through them. A broken spring could be causing your problem.
Luckily, any of the larger music stores should have them avalible.
Good Luck!
-Sheeves
Mar 02, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My reverb on my Fender deluxe Hot rod amp has stopped working. What is wrong?
Your reverb spring is most likely broken. If it has electronic reverb, then the chip has gone out. For both of these problems, a qualified amplifier technician will have to look at it and replace the parts.
Hope that helps!
Feb 13, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Hot rod deluxe reverb is on today tommorre it is off ???
Without more info can't be much help. IF you are using the foot switch, poor contact of the plug AND also of the switch contacts of the footswitch jack will lead to intermittent reverb. There are MANY components that can cause the problem, including some may be temp sensitive... you need to characterize what MIGHT be changing in the environment. Also does vibrating the unit cause any change? You could even have a loose connection or bad cables that goes to the reverb tank...
This may take electronic test equipment to find the cause. COuld be failing component, crack on the circuit board, bad connector, cable...
Feb 12, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My Fender Hot Rod Deville reverb is not working. What should I look for in trying to fix this problem
There are two coils in the reverb unit which use delicate wires which can break off - these can easily be checked, as follows:-
i) Remove one cable plug from the reverb unit & substitute an uncapped phono plug to the socket.Then check that there is electrical resistance across the plug terminals.
ii) Reconnect original phono plug & do same test as i) to the other socket.
iii) If either is open-circuited, then look for a break in the lead-out wires from the corresponding coil inside the reverb unit.
This break may be repaired (contact me for details) or buy a new reverb unit!
iv) If there is electrical resistance at both sockets of reverb unit, then clean both original phono plugs & try the system again.
Sep 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
