Question about Fisher and Paykel Refrigerators
Freezer cold , fridge not, both fridge sensor and evaporator sensors replaced - no difference- unit is RF601A- water has not been connected in 4 years after moving house.
OK I have the RF610A fridge on top and freezer below in french door arrangement. If sensor on evaporator and sensor in refrigerator have been replaced and both evaporator fan and fridge cooling fan are working but I still do not get cooling in refrigerator space and freezer is just fine what is next probable problem?? Evaporator coil did have a lot of ice around it when viewed before replacing sensor but this all cleared with unit turned off. F08 and spanner sybmol still up. What next please?? Never realy hear compressor running but I guess it must be working if freezer cold??
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
rpbuice
  • 161 Answers
SOURCE: Freezer gets cold, Refrigerator Hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You can't see the door but, you should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system which consist of the defrost timer, heater, and thermo disc.
Also, If you replaced the evaporator fan then you got a good look at the cooling coils. Look at these coils while it is running. There should be a light coat of frost on all the coils. If this frost line is only 3/4 or 1/2 or any amount less than full coverage of the coils then the system has a coolant leak.
Directly under these coils is the drain pan and drain hole in the middle. This area should be clear of any ice or debris.
Posted on Dec 25, 2008
landsend
  • 1066 Answers
SOURCE: freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Compressor not running, Fridge/Freezer not
Unplug refrigerator pull away from wall. Remove cover over compressor and feel top of compressor to see if overheating or trying to start. If too hot to hold hand on top leave unplugged until we locate the problem. This could be capacitor, start relay, overload, motherboard. This can Be fixed but we need to eliminate cause before replacing any parts. Sea Breeze
Posted on Jan 23, 2010
Have you checked the fridge thermostat? If the thermostat is ok then you should trace the volts which operate the valve which connects the compressor to the fridge evaporator coils. If the valve is getting volts then the valve is faulty. If not fault lies with control circuitry.
May 08, 2014 | Fisher and Paykel Refrigerators
Fridge warm, Freezer OK
You will find very good info HERE.
Good Luck.
Mar 03, 2008 | Samsung RS2578BB Side by Side Refrigerator
Tip
Refridgerator warm and freezer is icy cold
Frost free fridge freezers are very popular and auto defrosting fridges are a great convenience. In a frost free appliance the cold air is blown round the freezer using a fan. On modern refrigeration the evaporator (which is the plate that gets cold) is hidden behind the plastic wall inside at the back of the food shelves. When working correctly you can usually see small beads of ice randomly scattered on the back wall unless it's in a defrost cycle when you may see water.<br /> Heater inside Believe it or not most modern refrigeration has a heater inside. This heater is used to defrost the appliance automatically. During the defrosting cycle the ice on the back wall melts and runs down the back wall into a channel. It is then directed through a hole out through to the back and runs into the evaporator tray. The evaporator tray is on top of the compressor which gets pretty hot and evaporates this water into the air.<br /> Because the evaporator is behind a back panel the cold air has to be blown around the compartment with a fan motor. The defrost cycle also needs sensors and a timer and combined with several sensors throughout and PCBs to control everything the result is there is a lot more to go wrong than there used to be in old-fashioned conventional fridges. However, they are still fairly reliable.<br /> Common problems with frost free fridge freezers If the door is left open for too long (especially in humid conditions) the evaporator freezes over and the unit will not keep the food cold. This problem (unlike the older machines) has a greater impact because you can't see the amount of ice built up around the back of the panel hiding the evaporator. In many frost free fridges the ice can form all the way round the fan and cause it to run slowly or even seize up. Prior to seizing up the fan may catch on the ice and make a high pitched noise. This will of course result in the fridge or freezer not getting cold. If you hear a strange noise from your frost free fridge freezer which sounds like something is catching on a rotating fan it could be due to ice forming around it.<br /> If it stops working due to ice forming behind the evaporator and round the fan then defrosting the unit manually can fix it but it involves unplugging the unit for at least take 12 hours or so. You may not see much frost as it would be behind the back wall or behind the fan unit. You can't really use a hair dryer on modern units because they may have a thermal fuse which protects the defrost cycle. Also, even just getting to the evaporator to defrost it can be a mammoth task especially with some of the new American-style fridges. If a fault re-occurs later it could be due to faulty sensor but if the fault was only due to the door been left open for a few hours accidentally then a total defrost could work. <br /> Whilst we are on with American style frost free fridge freezer's, because the door's are so big and can store so much, the opportunity to overload them is greater. This too causes warm air to pass into the unit and frost it up. Remember a frost free unit will not cope with too much ice on the evaporator so greater care must be taken to use it correctly and check the door seal's regularly. <br /> <b>Water or sheet of ice inside fridge</b><br /> If your fridge has two sloping channels at the back wall and a hole in the middle this is designed to channel the water created on the defrost cycle through to the back of the unit where it runs onto an evaporator tray. This tray sits on top of the compressor and gets quite hot. The water simply evaporates. Sometimes this hole gets clogged up and prevents the water running out to this tray. The result is that water runs into be base of the unit. Very often the appliance will come with small tool for cleaning out this hole, but if not you can improvise.<br /> If the water in the base of the unit is frozen solid it could be that the unit has malfunctioned and is over freezing. The blockage preventing the water running through to the evaporator tray could actually be solid ice.<br /> <b>Summary</b><br /> It's common knowledge that most people rarely read the instruction book supplied with their new appliance. This is particularly true with something like a fridge or freezer. It's easy to imagine most people thinking you only need to plug it in, leave it plugged in, and fill it with food - what's to know?<br /> I would advise anyone with a modern refrigeration appliance, especially the American-style fridge freezers, to carefully read the instruction book. Modern frost-free refrigeration units work very differently to a conventional fridge or freezer. It's even important to learn how to stack them properly otherwise you can prevent the air from circulating inside and cause warm spots.<br /> You would be surprised at what you can learn from reading the instruction book.<br /> Many <a href="http://www.washerhelp.co.uk/instruction-manuals.html">User instruction manuals</a> can be downloaded here. The page concentrates on washing machine manuals but links to appliance manufacturer sites where users such manuals for fridges, freezers and other appliances should also be available.
on May 22, 2011 | Refrigerators
Refrigerator won't get cold. Freezer is real cold. Refrigerator always leakes water. Thank you.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged 5. defrost cycle not functioning properly if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional.
Nov 09, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
The hole at the back of fridge is not letting water go down so i have puddles of water running to front of fridge have tried cleaning out but just the same
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 14, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Cleaned the coils but freezer not freezing and inside not getting cold what is wrong
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged 5. defrost cycle not functioning properly if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. there defrost cycle starts with the timer. at a certain time of day for a specific time, the timer turns the compressor off and turns on the heater element located at the bottom of the evaporator coil. this stays on until the coil temp sensor reaches a certain temperature to let the timer know that the coils are defrosted and turns off the power to the element. the defrosted water drains to the condensate pan. if the timer is bad, it will never go into defrost, or never get out of it. if the element is bad, the coils will never defrost. if the temp sensor is bad, it?ll go into defrost, but it will either tell the timer that it?s always frozen or already defrosted, resulting in the element never turning on (stays frosted) or never turning off (eventually burning out the element). defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Sep 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig temp not cold enough..drinks are almost warm
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Fridge isn't cold, but freezer is working fine
Aug 21, 2009 | KitchenAid Refrigerators
2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Aug 18, 2009 | Refrigerators
Refrigerators Logo
22 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
