Question about Sony Alpha DSLR-A100 Digital Camera
I have the sony a100 alpha... it wont take a photo. 4 red zeroes
I did a chat with Sony tech. His troubleshooting did not cure the problem. He told me to reset the camera (remove the battery, turn the power switch on, and reinsert the battery).
After two attempts I still have the 4 flashing red zeroes in the bottom right screen and camera will not take photos.
Tech said "unfortunately, your unit requires repair" and asked if he could forward me a link where I can find a repair location, the Sony repair cost, or initiate a repair. I declined hoping to find the solution on some forums such as this one.
  • travelingsen Jul 03, 2009
    Howdy from Texas, Ayodurodola.
    Your solution was perfect. I'm ashamed that I didn't think of it. But then, it's too bad the Sony Technician didn't volunteer the information rather than have me re-set the camera and then tell me it will cost $225 to fix the problem.
    You really made my day. Thanks so much from a 71-year old grandfather who enjoys taking sports photos of his grandchildren. The Sony A100 works for me in that respect.
    I have not even tried to exploit some of the camera's other capabilities. That should be no surprise considering I couldn't even recognize that my memory card was full.
    Thanks again.
    Gary
Check the memory stick if its full and delete some photos......then try and take a shot.
the four red zeroes are counters for the number of shots u have taken.....it simply indicates you have a full memory stick.
Mine played the same trick on me too.
Posted on Jul 02, 2009
  • Raven Quesenberry
    Raven Quesenberry Nov 16, 2013
    Did you just go through and delete shots from the camera itself? Because I've done that, and it fixes the problem...sorta. It only lets me take one or two pictures after having deleted previous pictures. Please help.
However, having reset the camera, reset all the functions, recharged the battery, re-read the manual, and FINALLY, viola, as above, erased a few shots and the camera works again! The memory stick was full!
Thank you.
Posted on Apr 11, 2010
  • Roger D Paterson MD Apr 12, 2010
    My problem (now "solved") was sudden in onset.
    Suddenly, I was unable to take any pictures although all functions seemed normal.
    The only other clue were the 4 red zero's in the viewfinder.
    My memory card was full!
    Such a non-intuitive solution to a vexing problem!
    Good luck, you other readers!
    Roger
    New Friend:
Had the same problem on my Sony a100 camera. I thought maybe my cf slot (adapter) had gone bad. I bought a new cf card (because Sony no longer makes the cf slot (THANKS SONY!!!) and now I can take pictures again.
Posted on Jul 30, 2015
Sony DSLR-A100 eroor 0x58
Does the error happen each and every time you take a snapshot, or only with some? As you are letting us know, have a look around the user manual to see if it can be of any help:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Flash does not work
Are you sure flash is enabled through the settings? Try to troubleshoot the issue using the user manual:
Mar 02, 2014 | Sony Alpha DSLR-A100 Digital Camera
Sony a100 wont turn on
If the battery is charged, try replacing the battery first. Also try turning on the camera with the charger plugged in. If neither helps, you will probably need to have the camera sent for repairs, but you can still try checking out the user manual for helpful information:
Nov 11, 2013 | Sony Alpha DSLR-A100 Digital Camera
Take apart sony alpha a100
Before attempting to take the camera apart, make sure to refer to the user manual. It will contain diagrams and schematics for the device:
Jan 05, 2012 | Sony Alpha DSLR-A100 Digital Camera
While taking photos yesterday, my shutter button stayed down or wouldn't click. The "no lens attached" came on, even though I had just finished taking some photos. My Sony a100 is 5 years old and...
There is propably a connection problem between the camera and the lens. Try taking the lens og the camera, and reattach it. If this does not work, try cleaning the golden connectors on the lens and the camera. Use a q-tip, gently rub the connectors, and reattatch the lens. If this does not work, you should get the camera serviced at a repair center.
Mar 08, 2011 | Sony Alpha DSLR-A100 Digital Camera
Alpha DSLR-A100 Digital Camera: i got problem with memory card. keep showing the m...
not all memory cards fit sony alpha perhaps you have bought wrong cd.try using your sd slot
May 06, 2010 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha A100 shakes when I turn it on
It's actually, believe it or not, an anti-dust mechanism. All Sony Alpha A100's (mine included) do a little shake/vibration to help keep the dust off. It's nothing to worry about unless it lasts for more than a second.
May 14, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony alpha 100
IT happened to me.
When you're in the reading picture mode, go in menu and re-format your memery card.
It will fix it instantly.
Good luck
Feb 23, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
1,380 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
