Question about Comark KM20REF Reference Thermometer w/ PT100 Probe, Celsius Only
Comark reference thermometer fell down & its reading 1. how to repair?
Thermometer fell dowm from a distance of 60 cm & its is reading 1. it is not showing me the accurate temperature. how tomake it normal.
The actual distance d varies directly as the distance s on a map. If 2 cm on a certain map represents 15 km find the actual distance represented by a distance of 70 cm on the map.
70 cm is 35 times larger than 2 cm so it represents a distance 35 times larger than 15 km, or 525 km.
Sorry I can't give you the exact keystroke sequence to calculate it as you didn't specify the make and model of your calculator.
Jul 21, 2011 | Office Equipment & Supplies
Won't stop filling with water & won't agitate
Welcome to FixYa.
You've haven't specified if this is a new or recent install, but here`s what I find is most common when dealing with the symptom you`ve described ( as long as water isn't filling over the top...that indicates a different issue )
I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far.
If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, ( refer to your manual, but it is typically recommended to be about "48 to "60 in height but not more than 90" or so )
**The standpipe drain requires a minimum diameter standpipe of 2" (5 cm). The minimum carry-away capacity can be no less than 17 gal. (64 L) per minute. A 2" (5 cm) diameter to 1" (2.5 cm) diameter standpipe adapter kit is available. " The top of the standpipe must be at least 39" (99 cm) high and no higher than 96" (244 cm) from the bottom of the washer.**
Also if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon.
Check your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. If not we can move forward from there.
Thank's for coming to FixYa and good luck.
Regards,
Macmarkus :)
Feb 22, 2011 | Kenmore 24032\24036 Top Load Washer
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
1996 hyundai lantra cylinder head torque spec
Revised Bulletin
This TSB supersedes the Cylinder Head Bolt Torque Specifications previously described in TSB # 96-20-003, TSB # 96-20-003-1 and TSB # 97-20-004.
DESCRIPTION:
This bulletin provides torque specification corrections to the 1996 and 1997 Elantra Shop Manual, 1997 Elantra Service Data Book, 1997 Tiburon Shop Manual and 1997 Tiburon Service Data Book.
Please record the corrections (listed) in the appropriate manuals and write the TSB number on the bottom of the pages listed below for future reference.
CYLINDER HEAD BOLT:
(M10) 30 Nm (300 kg.cm; 22 lb.ft) + (60°to 65°) + (60°to 65°)
(M12) 35 Nm (350 kg.cm; 26 lb.ft) + (60°to 65°) + (60°to 65°)
Nov 21, 2010 | Hyundai Motor 1996 Elantra
An ant carries food at a speed of 1 cm/s. How long will it take the ant to carry a cookie crumb from the kitchen table to the ant hill, a distance of 50 m? Express your answer in seconds, minutes and...
Since there are by definition 100 cm in a meter, the distance is 50x100 or 5000 cm. At 1cm/s it takes the ant 5000 seconds to cover the distance. There are 60 seconds in a minute, so it takes 83 minutes and 20 seconds.
Sep 14, 2010 | Casio FX-115ES Scientific Calculator
How many feet and inches is 182cm?
1 inch =2.54 cm
182cm =182 cm* 1 in/2.54 cm=182/2.54 in =71.65354331 in
1 foot =12 inches
182 cm = 60 inches + 11.65 inches = 5 feet 11,65 inches
You can use this result or say that 182 cm is about 6 feet.
Mar 28, 2010 | Texas Instruments TI-83 Plus Calculator
When you change the temperature of either the freezer or refrigerator, how do you ensure it changes? We press up or down, and a "set" light comes on, but then the temperature doesn't change.
When you adjust temp settings you will need to wait a minimum of 24 hours for refrigeration system to stabilize, so make only 1 adjustment per 24 hours.As how you can detect the temp change, just like a tech would do, buy one of those referigerator thermometers put inside and see what it reads after the 24 hour stabilazation. Good luck !
Dec 05, 2009 | GE Profile Stainless Bottom-Freezer...
Is the wide converter attachable?
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Comark KM20REF Reference Thermometer w/ PT100 Probe, Celsius Only Logo
51 people viewed this question
Top Comark Home Experts
john h
Tom Chichester
Are you a Comark Home Expert? Answer questions, earn points and help others
