Question about Health & Beauty
I have a bladez moby xl 40 cc scooter. And my back tire is shakin bad. When I ride the back of the scooter goes up and down.
  • 104 Answers
It needs to either be trued (vertically) or balanced.
Take it to the shop
JOAT
Posted on May 09, 2014
3 Suggested Answers
  • 16 Answers
SOURCE: Legend XL 4-Wheel Scooter w/55 AH Batteries & Charger/Flat-Free 13" Tires/22" Seat - Color Viper Blue - Gray Vinyl Seat Coverings: have a legend XL. battery 1/2 charged, lights and ...
Check the brake at the back of the scooter
Posted on May 21, 2010
SOURCE: put in new batteries and scooter will not do anything
It could that your potentiomenter is broken and would need to be replaced. simply removed the housings from both sides to get to the throttle part and check to see if the spring is not broken. if it is broken, simply remove old one and buy new one which should be around 60.00 and up in cost. can go to this website to check
http://www.monsterscooterparts.com/mobility-scooter-throttle-pot.html
Posted on May 24, 2012
Electrical shuts off or slows down when riding
You may need to replace the battery even though it is charging. It sounds like a bad battery or the motor may be overloaded.
May 06, 2012 | Pride Mobility Products Legend 3-Wheel...
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
My 2009 Nightster tire pressure - I'm seeing/hearing/reading different suggestions. I single ride. right now Front tire is 31, rear tire is 40, is this exceptable. Thanks
Yes, this is acceptable. I prefer to set the front tire at 30 and the rear tire at 36 when riding single. It's a matter of ride quality preference. As long as the tires are inflated enough to prevent excessive flexing of the side walls, you are safe. By lowering the air pressure, you get a bit better traction as your tire's "foot print" is a bit larger but it doesn't handle quite as quickly either.
Good Luck
Steve
Jun 09, 2011 | 2011 Harley Davidson XL 1200N Nightster
Battery passed load test; it still keeps on stopping
Check all of your connections as well as the fuses. Sometimes the scooter will stop if all tires are not getting traction or if one spins out form riding on sand, gravel or a slick floor. If the batteries test at full voltage output then there is something that is breaking the circuit or a built in safety measure is shutting the scooter down as if senses something is unsafe. Are there any flashing lights, vibration or noises when operating the scooter? Try to reset the freewheel lever or any other circuit breaker your model may have. If you continue to have the problem, contact the manufacturer or sales office for service.
Oct 20, 2010 | Pride Celebrity Xl 4 Wheel Scooter
How to fix a 49cc pocketbike forks?
some times its better to get new forks, as they can be stressed when straightening them, you dont need them snapping off while your riding
Apr 12, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have bladez moby that im being able to start but not to keep running, i used the ratio of 30:1 oil mix im not sure if its ok
Ok sorry you havent had an answer yet lol , here it is , i had this same issue . All you have to do is take the plastic cover off of the motor , and once its off pull the throttle ( with scooter off ) and you will see where it leades to . Where it leads to there is a screw which can be tightened to increase its motor stength / use . So tighten it , but only a little bit , if tightened to much the scooter will go without you pulling the throttle , so a 2-3 twists on a screw driver should do it. Once done , start your scooter up , and it should run great !
Dec 17, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
WILL NOT IDLE
vaccuum leak, or idle adjustment screw maladjusted.
Sep 28, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
How do I change the clutch belt on my BladeZ Moby motorized foot scooter (25CC)? Do you have any instruciton manual type pictures as I can't download any from the manufacturer?
there are 4 bolts that hold the engine in place on the left side of scooter when your looking straight towards the bars
then there are 3 more bolts below those tak em all all be carefull not to loose the small spacers behind the large ons there hard to notice but they are there
slip you belt over both pulleys and reasemble using the 2adjustment screws that attach to the big pulley on bottom until the belt is 110 & straight and has a little bit of play abotu half in or so should be fine you dont wat too much other wise it will break if you hit a bump or whatever an if its too loose wellit will slip as you might know
Jul 15, 2009 | Bladez 320-5M/25 Clutch Belt for BladeZ...
Moby bladez pull cord spring out how do i assemble it
The only trick to getting this back together is patience and determination. You must keep the spring flat as you wind it tight.
Jim
Jun 09, 2009 | Poulan 12a Elec Blower/Vacuum
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
