Question about Dishwashers
I have a 6000btu unit and the problem I'm having is when I plug it in all the lights light up showing power but then all go off. And unit will not turn on.. How do I fix it? Does unit have a built in delay because every summer I've had this problem and it seems to fix its self eventually
  • 104 Answers
Would this be an air conditioner, an ice maker or ???
Check the capacitor.
JOAT
Posted on May 09, 2014
I can not get the filter light to turn off after I cleaned and replaced the filter. I unplugged and reset the unit already.
If the filter was really dirty you could have plugged up the evaporator ( the thing you are trying to keep clean with the filter )
Try,removing the filter and using a spray bottle with a strong stream and spray into the evaporator to wash it out. If this does not work find a local appliance or refrigeration supply house and purchase a can of evaporator cleaner. When sprayed into the evaporator it should react with the dirt, foam up and remove the blockage
Aug 13, 2016 | Norpole 6000BTU Window Air Conditioner...
Power cord will not show power on when plug in
could be a broken cable its a common problem with laptops
Feb 18, 2015 | Computers & Internet
Wont turn on
On all Panasonic Toughbook Models,
if the unit will not turn on try the following:
Step 1: Unplug the unit.
Step 2: Take OUT the Battery Pack.
Step 3: Plug-in the unit.
Step 4: Turn On the unit.
The battery pack acts like a giant capacitor and can
prevent the unit to turn on, especially when the unit
was previously used on battery pack and was allowed
to fully discharge to below 5%.
When the unit is turned on WITHOUT a battery pack,
then a single Green light should show on the front
edge of the unit when the cover is open facing you.
When the unit is plugged in WITH a battery pack,
then you should see a yellow, orange or green light
which shows the battery is charging. When the unit is
turned back on, then you should see two (2) lights,
one green and the other yellow, orange or green.
If the unit is plugged back in and either with the battery
in or out you see no lights whatsoever, then chances are
that something is wrong with your AC Adapter/Power Supply.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Feb 18, 2014 | Panasonic Toughbook Computers & Internet
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
Does not turn on
Does power indicator show light when unit plugged in?
If no light upon unit plugged in that indicates power supply failure. Let me know your findings to provide you helpful info.
Can you check voltage in cd player with multimeter to provide you mode technical info to solve the issue.
Thanks.
Nov 26, 2010 | Sony CDP-CE545 5-Disc CD Changer
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
IBM thinkpad does not power up. Nephew watching
Could be the power button shorted, Does it operate when not plugged in?
The plug jack on the back where the pc would be plugged in, sometimes loosens and needs to be resoldered too. If the pc works when not plugged in, but does work on just the battery.
If no power on during either, it is probably the power on switch gone. Any lights whatsoever showing?
Jul 15, 2009 | IBM ThinkPad R50e Notebook
IBM X226 server
i have two x-series server but in one server with one power cords it is showing green light but in case of another server it is comming yellow light.
Nov 24, 2008 | IBM xSeries 226 Server
I Have A Compaq Presario That Will Not Power Up.
It sounds like your power supply unit as some leaky components, normally the bad powersupply unit show these types of symptoms. Try borrowing a powersupply unit from a friend that is similar to yours and replace to check if the powersupply unit is the culprit. If cornfirm PSU, than you neet to get yours fixed.
Nov 11, 2008 | Compaq Presario 5000 PC Desktop
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
