Question about Prestige Remote Start
After the timer runs out, car alarm comes on and wakes everyone. can this be disabled?
After car is started by remote it runs for 15 minutes and timer is displayed on the remote. when timer runs out car turns off but the alarm goes on. also I noticed that if I cancel the remote start while it is running by pressing the key button twice, the alarm goes on as well. any ideas how to avoid waking all the neighbors? (Toyota prius 2010) Much Obliged
jmgldsmth
  • 2005 Answers
SOURCE: alarm remote dropped in water alarm enabled on car..no entry
open your remote soak the circuit board in 90% rubbing alcohol then blow dry on medium heat it should work as good as new
Posted on May 03, 2009
  • 55 Answers
SOURCE: Hi ... My hyundai sata fe has a Prestige Keyless
What you need to find is the valet button which i believe is the blue blinking LED that should be in the dash and it blinks when you arm the system. So try this.. disarm the system and get into the car like normal than put the key into the ignition turn the key to "run" and press and hold the blue LED button till it turns solid. You are now in Valet mode which means the alarm is OFF. Now try starting the car and see if it starts all the time. If it doesn't start and the little blue light is on solid than we have other problems. Because with the alarm in Valet mode the starter disable feature is turned off. However if it does start all the time and gives no problem you might have a loose ground that has to be tightened up or other wiring issues. Now for the alarm going off at random times, you have whats called a "shock sensor" that is adjustable. What this boxs job in life is is to wait for any "impact" like a breaking window or something hitting the car. Notice i didn't say motion. The shock sensor is adjustable and this could be the random going off problem. The shock sensor would be a little box zip tied to a wire loom under the steering column. let me know... mark
Posted on Aug 16, 2009
  • 7 Answers
SOURCE: hit the button twice,truck starts then dies.will
to test this put ur key in the ignition but dont turn it if it starts then its detecting the key and u know as soon as u pull ur key out it wont work its a security bypass issue
Posted on Dec 15, 2009
  • 11 Answers
SOURCE: The prestige alarm system i have will not let me
WHEN U UNPLUG THE ALARM BRAIN THE TRUCK SHOULD START.CHECK THE STARTER WIRE IN VEHICLE.IF CUT MAYBE NOT A GOOD CONNECTION
Posted on Jul 26, 2010
logosc75
  • 625 Answers
SOURCE: When use remote starter to start car, factory
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Posted on Nov 12, 2010
HOW DO I DIS ENGAGE THE SECURITY FEATURE ANTI THEFT MODE 2010 AVENGER
You can't disable it. Newer Dodges have chips in the key. Older Dodges you could lock the car down and open the door with the key to disarm the alarm. Try both doors. The latch sensor in one door could be broken. If still no luck, you'll have to get it on a scanner to read codes. Code readers don't read security codes.
Jun 13, 2015 | 2010 Dodge Avenger SXT
Automatic wake up call
i dont know the model of the lcd but i will try help, click the menu button on the lcd or the remote , look for something that say's Timer, Wake up , Alarm , Auto on , Auto power , Auto Switch , if you find any of these option's play around with the setting's there should be a clock type thing to change and a off / on , tab to select , it also maybe under the time/clock options , otherwise on the remote look for a button that when u press, on the screen you will see something like 5 hours, 6 hours, or any time /clock looking display that comes up on the screen, and keep pressing it till it says off or -- , or zero ,
Good Luck
Dec 22, 2007 | Televison & Video
Disable timer on avital remote control
i think the engine rev needs to be turn down a little
Jul 14, 2014 | Hardware & Accessories
How to disable the car alarm but keep the remote starter operational
Find the owners manual for the specific model you have and follow the instructions for placing the system into 'Valet Mode'.
May 10, 2014 | Audiovox Vehicle Parts & Accessories
My viper 5902 central controller won't response
Replace your Batteries on your remote control sounds like the batteries are not giving enough power ,so the radio in the remote to trigger the alarm to disable the alarm is not strong enough.Its like the power of the batteries show light but its not strong enough.
Jan 08, 2014 | Vehicle Parts & Accessories
My daughter has a hyundi lantra 2000 or 2001. last night her remote on her key did not unlock her door so she used the key. My Q. does any body know if there is an over ride button for the engine...
if it's a 2001 my info doesn't show the 2001 Elantra GTS as coming with an alarm. GT does have keyless/alarm. Are you sure its not just a keyless entry system? Test it by doing the following: Close all doors and sit in car, 'arm' the alarm with the remote, wait about a minute and open the door from the inside...if the horn starts beeping you have an alarm. If nothing happens, you only have keyless entry.
Anyway disarming a ETACS alarm system is not a option.
Jan 15, 2018 | 2000 Hyundai Elantra
Car alarm was not set opened door and car was disabled now wont start
what wont start the car alarm or the car? if its the car you need to shut the door. unplug your key turn the alarm back and if you havfe remote start turn it on then shut off remote start and disable the alarm should reboot the alarm system. if not unplug the battery for about a minute it will reset the alarms disable car start feature
Mar 16, 2011 | Scytek 5000RS-2W Plus Full featured auto...
How do i disable my seat belt alarm sound
You must lock the doors first using the KeyFob - then press and hold the remote start button for 3-5 seconds.
To disable the seatbelt chime, you must either wear your seatbelt, install an aftermarket radio (as the chime plays through the speakers), or find a used one in a junkyard - cut off the seatbelt and plug it in - Chevy does not have an override... however it will only do it 3 times in 15 minutes - then stop bothering you.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 02, 2009 | 2008 Chevrolet Cobalt
The car alarm and key pad will not disarm and the car will not start.
Normal system operation - when the burglar alarm is active, the starter circuit is disabled. Is the battery dead or weak in the keyless remote? Also, is the remote you have been programmed for this vehicle? If the answer is 'yes' to both questions, replace the battery in the remote. Otherwise, place your ignition key in the ignition and turn the key to 'run' (or 'ON") wait 5 minutes, the vehicle should start (if the battery isn't dead).
May 22, 2009 | 2003 Hyundai Tiburon
Prestige Remote Start Logo
32 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
