Question about Whirlpool Washing Machines
Does anyone else have trouble with whirlpool washer model wtw4800x02 grabbing and tearing clothes
Agitator has slots at bottom that catch and tear clothes
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Check the agitators are secure in the drum and carefully check the inside of anything jammed in the drain holes. best to use a torch and wooden spatula than fingers just in case its sharp
Posted on May 31, 2014
Kenmore/Whirlpool WASHING Machine #110.26752502 top load Not Rinsing Thoroughly
usually the dogs in the upper agitator go bad. your agitator is two pieces. grab the lower agitator and turn the upper agitator. if you can turn it, the upper, back and forth. the dog cams are bad. very common problem. if they are stripped, clothes will not agitate in wash or rinse. plus machine can go out of balance easy. usually caused by normal wear and tear but is also a sacrificial piece in the even of an overload. common tools repair. good luck.
Kihm Skillicorn
Jun 14, 2017 | Washing Machines
I keep getting clothes wrapped in the fin of my GE washer.
The problem is wear in the fins and bearings. Replace the whole rotor assembly and bearings or buy new machine. Can I suggest a front loader
Nov 03, 2014 | Washing Machines
Why is my whirlpool deut washer tearing clothes
Check the little holes around the drum, I have seen pins and needles get stuck in these and cause lots of damage. I would replace the seal.
Apr 10, 2013 | Washing Machines
My problem is the agiator tears my clothes what is wrong this does not happen everytime just sometime and ravels towels?
Perhaps you need to remove the agitator and look under it for objects that do not belong.
In the past I have found items of clothing and such.
Cabrio service manual
Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Tearing clothing
Either use a more gentle cycle or the agitator may be off centered or could have bad coupler or bearings. Otherwise check the seal on top of tub to make sure it is not ripped and catching clothes
Sep 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Agitation issue
So you say the agetator is moveing or when the clothes go up and down does it stay in place and make a rattcheting sound. if it is not moving the clothes up and down you need new agetator dogs. pop the cap off the top of the agetator some have a plastic cap that you can poull off to get to the 1/2 inch screw inside. some don't if you can see the bolt around the edges of the inside of the agetator you will see groove marks and when you turn the agetator by have you will see 4 plastic tear drop looking thing that grab the grooves of the agetator these tear drop things get stripped over time. replace them and this should solve your problem. let me know if you have any more questions
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Holes in clothes
Be carefull not to overload and inspect around door and heat entrance area for catch points or sharp areas.
Its usually Washers that tear clothes inspect closly to determin cut or tear. if tear try smaller loads with only similar materials
Dec 31, 2008 | GE DCSR483EA Electric Dryer
Top agitator doesnot work
Your agitator dogs are worn out. They are 4 small pieces in the agitator that act as one way clutches. They allow the top section to turn one way but catch the other way. Pretty simple fix.
If you will post the complete model number I will find the part numbers for you and try to provide instructions on replacing them.
Nov 26, 2007 | Whirlpool LSB6200PQ Top Load Washer
Washing Machines Logo
203 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
