Question about AIMS 5000 Watt 12 Volt DC Power Inverter to 220/240Vac 50Hz
How fix a inverter
How to fix it
  • 104 Answers
Too vague, but look for bulging capacitors and replace them as needed.
JOAT
Posted on May 09, 2014
Hooked my inverter backwards so blew fuse how do I fix my inverter?
If the inverter does not have reverse polarity protection, there may be a few components on the circuit board that may need replacing. If replacing the fuse didn't fix it, then you'll have to seek a repair center from the manufacturer's website or from information from the owners manual.
Oct 01, 2016 | Cars & Trucks
How do i fix my su-kam 2.4kva inverter that stopped charging the batteries?
A 2.4 Kw inverter is serious equipment costing quite a lot of cash - rather too much cash to take a chance with. The very fact you have to ask how to fix it means you probably shouldn't touch it but should entrust the repair to a properly insured professional.
I suggest you check the literature provided or visit the manufacturer's website for advice, make whatever checks you can regarding external connections and wiring and then find a repairer.
Aug 01, 2016 | Inverter Electronics - Others
PACKARD BELL EASYNOTE SJ51. NO INVERTER VOLTAGE. ALL LEDS OK, SOUND OK, BOOTS OK, SCREEN BLACK OR POSSIBLY DIM.
Simple test: get a flashlight, go with the laptop in a dark room and point the flash light at the screen. If you see the image then indeed the inverter isn't working. of you don't see it then the data cable between the motherboard and the screen has been damaged: replace it.
If the inverter is at fault you will need to open the screen cover and check if the inverter board receives power from the motherboard: if it does you need a new inverter board
http://sparepartworld.com/display-inverter-board-for-packard-bell-easynote-sj51/product_info.php/products_id/1724545
If it doesn't then a complete testing of the motherboard will have to take place to find out why and if it can be fixed.
Aug 12, 2011 | Computers & Internet
My samsung hl-r5087w has black verticle lines how do i fix that
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help to fix the fault, do take care in handling the solution
May 26, 2011 | Samsung HLR5087W 50" Rear Projection HDTV
My 37 in rca, model # L37WD12, Will not fully turn on. it tries to come on, but the green light just flashes. and the tv makes a small ticking noise that goes with the flashing. how do i fix this or what...
The inverter is probably bad - the ticking noise you hear is high voltage that is trying to turn on the backlight from the inverter's transformer but cannot. The only way to fix this is to open the TV and locate the problem around the inverter circuitry. Another possibility is there is an open circuit run around the inverter and may just need some solder to bridge the open.
Jan 16, 2011 | RCA L37WD12 37 in. LCD HDTV
Toughbook is on but screen is black
Ok that means your lcd inverter has went bad or the backlight ,,but usally the lcd inverter,,can find both on ebay,,cheap uaslly,, but the inverter probly your problem ,,definetly would start there,,easiest fix,,find you a lcd inverter,,,,ebay or internet,,when u get it,,take bezel off lcd ,,the front cover with screw driver,,be easy ,,take ur time ,,once off ,,in the middle of lcd @ bottom theres lcd inverter ..exchange for new one ,,turn on and check b4 u put bezel back ,,on,,should be good to go,,if that doesnt fix,,backlight bad,,easy to find also,,goodluck,,
Nov 20, 2010 | Panasonic Toughbook 28 Notebook
My inverter started flashing its green light now it wont turn on, i have checked the internal fuse's they are good, next i checked the fuse's in my car and they are good, i even tryed plugung in another...
This inverter is a good Walmart inverter.
I had one that worked for about 6 months.
There really is no affordable fix.
RECOMENDATION:
Take it back if you can as soon as you can, dont fix it..
Hope this Tip Helps.
r/
David
Jan 09, 2010 | Black & Decker Power Inverter PI400AB
I have a 42'' plasma is it worth fixing it
Definitely worth fixing. You may be able to locate an inverter on the internet. Try ebay first. Have seen the inverter for that set for under $50.00
Sep 25, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Fix inverter
if you are technically capable and know how to troubleshooting electroics. the answer is yes.
you going to need a schematic. as far as I know these diagram is very hard to come by. no vendor want to let it out.
good luck
Oct 15, 2008 | Monster Cable Monster Mobile PowerStation...
AIMS 5000 Watt 12 Volt DC Power Inverter to 220/240Vac 50Hz Logo
124 people viewed this question
Top AIMS Electronics - Others Experts
Are you an AIMS Electronics - Other Expert? Answer questions, earn points and help others
