Question about Dual Car Audio & Video
Video output of Jensen radio is connected to input of headrests. The image comes throug but switches off at times just giving a blue screen. how can I rectify this?
5 Suggested Answers
  • 14 Answers
SOURCE: Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Posted on Mar 08, 2007
LVT7857
  • 116 Answers
SOURCE: Jensen vm9511ts (Video Feed)
I know that the Jensen has a "Dual Zone" setup in the menu settings. Make sure that you have it set right. Make sure nalso that you are using a MONITOR OUT RCA from the Jensen, not a source input on the deck.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Posted on Apr 09, 2009
SOURCE: it just shows a blue screen and says no video on jensen uv10
yes
Posted on Feb 28, 2010
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Wires
Wiring Connections
1. TV TUNER
2. ANTENNA
3. POWER ANTENNA WIRE (Blue) – Connect to a motorized (power)
antenna and/or to a remote turn-on lead for an amplifier.
4. CONSTANT POWER WIRE (Yellow) – Connect the 12V PLUS constant
power wire to a live 12 volt wire in the vehicle. Before making a connection,
check that the wire you intend to connect it to is always live, even when the
car’s ignition is turned off. If a live wire is not found, route the wire to the
car’s fuse block and connect it to a live circuit there.
5. GROUND WIRE (Black) – Securely fasten the Ground wire to a grounded
metal part of the car’s chassis. If you cannot find an existing bolt or screw
to fasten it to, drill a hole in the metal and secure it with a screw. To ensure
a good ground, remove any paint or grease from areas where the wire will
contact the surface.
6. PARKING (Pink) – Connect to negative parking brake wire. This wire
MUST BE connected in accordance with federal, state and local laws. It is
the end-user’s responsibility to make sure this wire is connected properly.
7. ACC POWER WIRE (Red) – Connect to a +12 volt circuit that is only live
when the ignition is on. The best connection point is at the car’s fuse block
at the “RADIO” or “ACCESSORY” identified terminals.
8. LEFT FRONT SPEAKER (white, white/black)
9. RIGHT FRONT SPEAKER (gray, gray/black
10. LEFT REAR SPEAKER (green, green/black)
11. RIGHT REAR ( + ) SPEAKER (violet, violet/black)
12. FRONT AND REAR RCA OUTPUTS
13. CENTER RCA OUTPUT (Gray) – The center output must be connected to
an external amplifier for 3D or 6-CH mode.
14. SUBWOOFER RCA OUTPUT (Blue) – The subwoofer output is available
in all sound/audio modes.
15. DEDICATED DVD OUTPUT – Video output for rear screen and left/right
audio output for headphones.
16. AV1 INPUT
17. AV2 INPUT
18. VIDEO OUT (Yellow) - V. SEL output for rear screen.
Or you can go to link below for the manual page 4
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/VM9510_DOC_OM.pdf
Good Luck and please rate 4 thumbs for the free answer
Mar 31, 2010 | Jensen VM9510 Car DVD Player
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
How do i bypass the parking break saftey feature on my Alpine IVA-W205
put a switch on the brake wire make sure the switch is on the off position. the switch should have two wires ,one wire connects to the brake wire the next wire ground it to the car .then turn on the stereo put a dvd in and turn the swicth on and off several times .It should come on
Oct 02, 2009 | Alpine IVA-W205 Car DVD Player
Why dont i have a picture in my headrest monitors
are you hooked on the right output from the indash??
do your headrests have more than one input option??
or do they ever just say "no signal"
check that out maybe something got overlooked
Jun 23, 2009 | Jensen VM9510 Car DVD Player
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Apr 09, 2009 | Jensen Car Audio & Video
Larry T
Winona Lake, IN
Jan 23, 2009 | Jensen VM9510 Car DVD Player
Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
May 10, 2008 | Sony XVM-R70 7 in. Car Monitor
Car Audio & Video Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
