Question about BenQ Office Equipment & Supplies
Pmd 1000 ic fault - BenQ Office Equipment & Supplies
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 20 Answers
Sounds like a power supply issue, or lamp. More Power Supply. Do you get any LEDs on the unit showing any status?
Check mfg webpage to see if any warranty left.
Posted on May 09, 2014
I want online conversion PMD file to PDF file.
Here are directions: http://www.ehow.com/how_7375408_convert-pmd-files-pdfs.html
You can also try using ZamZar (http://zamzar.com/) or installing a free PDF printer like PDF Creator (http://sourceforge.net/projects/pdfcreator/).
Hope this helps!
May 31, 2011 | Computers & Internet
Checked Manual: 1996 chevrolet 3500 6.5 turbo. What is a(PMD)? manual doesnt list it.
Common Problems:
Pump Mounted Driver: Relates to thermal failures. The PMD is screwed to the DS-4 injection pump on the 1994-2001 GM 6.5 diesel utilizing fuel flow to dissipate heat. The injection pump is mounted in the intake valley (a high heat area). The PMD contains two power transistors that should be cooled by proper contact with the injection pump body. If the pump is not precisely machined to make complete contact with the transistors via the silicone thermal gasket and paste, the PMD is improperly installed without the gasket or paste, the PMD is installed off center with the pump body, or corrosion develops on the mounting surface the PMD will overheat. Several companies manufacture an extension harness and heat-sink kits. These allow an owner or their mechanic to relocate the PMD away from the injection pump to a lower heat environment and/or a place that can get more air flow.
Hope helps (remember to rate this answer)
Mar 19, 2011 | Chevrolet 3500 Cars & Trucks
My 1000 watt inverter has stop from supplying AC power
Unless the set is checked into , it cannot be confirmed if the fault is due to :
Failure of the switching semiconductors- drivers- Mosfets
Failure of the transformer
Failure of the switching frequency generator-IC
Failure of the in voltage detect or relays.
Oct 11, 2010 | Statpower PORTAWATTZ 1000 Watt Power...
Vostro 1000 wont charge also 2nd machine same model has a ic blown on mainboard where can i get a schematic diagram also is there a general known fault with the charging circuiton this model . Rgds
Schematics for Dells are generally unavailable.
The not charging is normally due to a failure on the charging circuit or damage to the power plug (If ac adapter will not run system or if you have to play with the power connection.)
Replacement motherboards start at about $75
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1000+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=dell+1000+motherboard&_osacat=0
Oct 06, 2009 | Dell Vostro 1000 Notebook
I want to convert pmd file in to word
you can go google.
jusf put "pmd to word",and then click "search".you can find the software support convert pmd to word.
Jul 31, 2009 | Adobe Photoshop 7.0 for PC
Deleted PMD file
If you have not disconnected the pocket drive, have a look in the Recycle Bin, if it is still in there click on the PMD folder to highlight the folder and click on File - then click Restore.
This will then restore the PMD folder to the pocket drive.
If you don't see the PMD folder in the Recycle bin, you may be able to download it from the HP WEB site.
Jun 23, 2009 | Computers & Internet
Epson 1000 ics printed picures streaked
try this
- print at slower speeds
- run the cleaning utilities(program) that came with you printer.
Mar 26, 2009 | Epson 1000 ICS All-In-One InkJet Printer
Pmd
the stock location of the pmd is on the side of the injector pump. if you stand at the front the vehicle look and the middle front top section of the motor right where the drivers side of the intake manifold starts to rise you will see it
Nov 17, 2008 | 1995 Chevrolet K2500
65 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
