Brivis zone hi I have a brivis me30i and just had the dam thing fixed (code50 and $900 later) Now its coming up with code 54 does anyone know what this means?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
$900 seems like a lot for a new HSI and flame sensors :( 54 seems to be with the supply air thermistor. does the unit still operate with the error?
Posted on May 23, 2014
4 Suggested Answers
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
potek18
  • 528 Answers
SOURCE: hi i have a brivis
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Posted on Jul 12, 2010
  • 3247 Answers
SOURCE: My brivis climate system (auto EMS series EMS20)
Have you seen this Instructions Manual which explains some of the actions to check the system.
Have you checked that the gas supply to your premises is working well. You will have to confirm there is no air in the system which is preventing the pilot from re-igniting.
Depending on where you live in Melbourne you can find a local repair technician who can help. Try the local newspaper classifieds. For the north & west try this mob. You can also try Service Central and post the job.
Hope the unit works soon. It must be awful not to have heating in winter.
Posted on Aug 22, 2010
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Jul 12, 2010 | Heating & Cooling
Hi any idea what causes this Brivis error. err
go to the brivis web page and type in serial number and error code theywill give you a code and repair instructions.adrian,,,,
Jun 29, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
What does a f 54 code mean?
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the top of the machine with a screw driver in the front you will find the manual on the inside of the front panel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Zoning not programmed
Hi ill be honest this is a little tricky
There are many variations depending on a few things.
Is it heating only or add on refrig as well?
Is there a common zone or an area constantly open?
How many networker controls 1 or 2
So any way this is the set up for heating only 2 zones and common zone.
Turn the networker wall control off
in the off screen press the clock key (the time will flash)
hold down the 2 & 4 keys for about 5 seconds
depending on the model and what other appliances are lincked to it it will display either
H01 ID01 1500 (NC3 2004 onward)
1500 01 H01 (NC1&2 pre 2004)
press the (M or mode) button till you get to the N1 parameters eg N1 ID01 01
press the number 1 key or on older models top key
should then display should read
N01 ID15 01(COMMON ZONE)
Then using the dial to change the setting to read the same as below once done press the number 1 key or top key to advance to the next setting
N01 ID16 01(NETWORKER NUMBER)
N01 ID17 01(ZONE A)
N01 ID18 01(RELAY NUMBER ZONE 1)
N01 ID19 01(NETWORKER NUMBER)
N01 ID20 02(RELAY NUMBER ZONE 2)
N01 ID21 01(NEWORKER NUMBER)
then press the number 1 key followed by the on off button then, provided its all been installed correctly zones should appear and operate :-) good luck and i hope this helps.
May 18, 2009 | House Brand Heating&Air Conditioning...
New codes for digivox xl plz
PROVIDER CODE: 54 01
codes are..... BO B8 4F O4 E6 5F 87 80 and A3 EB EC 07 D6 49 D2 EB
Just worked for me...
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
