Question about Garden
Spark plug gap
Model# 21603
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Follow the steps in the manual if you have a manual and if you don't have one I recommend that you get one.
Posted on May 09, 2014
Spark plug gap for a Polaris sportmans 500 a 2010 year
0.028
http://www.polarisatvforums.com/forums/atv-repair-maintenance/14769-spark-plug-gap.html
BKR6ES(STOCK#6364) regular, or IRIDIUM BKR6EIX(STOCK#6418).Gap setting is .028.
That plug is used on all 500 HO from 2000-2011 Sportsman Models.
http://www.polarisatvforums.com/forums/atv-repair-maintenance/40754-500ho-ngk-spark-plug-number.html
http://www.ngksparkplugs.ca/results-motorcycles.cfm?model=empty&enginesize=500&make=POLARIS&apptype=ATV
Here is your manual. Spark Plug page 93. Page 123 says
Spark Plug / Gap NGK BKR6E / .035 in. (0.9 mm)
Different plug (E rather than ES) and gap. check the plug that came out.
http://cdn.polarisindustries.com/polaris/common/parts-manuals/9923420r01_lo_res.pdf
Jul 10, 2016 | Polaris 2004 Sportsman 500 H.O
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
1984 40hp mariner 2sroke spark plug gap
Need more model information to be accurate and the manufacturer's recommended gap isn't always the best gap for different spark plugs.
In the absence of technical information for the engine the recommended plug gap in the spark plug manufacturer's application catalogue will be the best for that product.
A typical gap for a 2-stroke spark plug with a standard low energy ignition system is in the region of 22 thou. A high energy system will spark across a bigger gap but the spark is typically weaker at hand cranking speeds and so a smaller gap (24 to 28 thou) is still needed for easy starting unless the ignition system is battery powered rather than by magneto.
Mar 24, 2015 | Boating
Correct spark plug gap for volkswagen 1400
In general, when it comes to Volkswagen plug gaps, the spark plug gap for fuel injection models is (.028 inches) and the gap for carburetor models are set at (.024inches). Whether it is fuel injection or carburetor is what is important.
Nov 21, 2014 | Volkswagen Cars & Trucks
Gap required in spark plug for peougeot cars
0.3 , 0.8mm gap required in spark plug. and heat the plug
Oct 21, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
Spark gap for 2009 hyundai tucson 2.0 litre
The Manual says .044inch, Some plug makers advise not to change there preset gap. Most plug charts recommend the gap for most makes and models.
Oct 18, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
Spark plugs gap
no engine stated? wow. 3.5L? says no gap settings.
its in the FSM. many cars dont put it in the op guide as the plugs
are rated to 80k miles or more, and is not consider, operator deal.
sadly.
and many folks think the new plugs are set in the factory , WRONG. (comment is for J plugs not surface fire tech)
i see you are there.!
many stores, list it wrongly too.... vast....
but you never said country car was sold.
in the USA we open the hood, look up and behold, its right there.
the vacuum and turn up sticker,
now alldata.com
quotes to follow.........all.
the original equipment spark plugs installed in the Odyssey 3.5L V-6 engine are platinum tip spark plugs, and the plug gap must not be adjusted.
and other warnings, and the no file them warn.g
On CR-V and 4-cylinder Odyssey models, adjust the spark plug gap to 0.039-0.043 inches (1.0-1.1mm). On Odysseys with the V6 engine, check, but do not adjust the spark plug gap. The spark plug gap should be 0.039-0.043 inches (1.0-1.1mm). If the spark plug gap exceeds 0.051inches (1.3mm), replace the spark plug.
so 1mm , if not v6
Sep 07, 2013 | 2000 Honda Odyssey
What is the spark plug gap setting for a Saab 9-5 (1998 2.0l model)
The spark plug gap setting for a Saab 9-5 (1998 2.0l model) is: 1,0 ... 1,1 mm.
Please do rate my response. Thanks!
Jan 06, 2011 | 1999 Saab 9-5
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
