My copier machine 2870 give error code e00002-0000 what can i do?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
It's a heat rod error code. It can be reset but will come right back untill the problem is fixed.
Posted on May 10, 2014
Cogz
  • 1326 Answers
SOURCE: Trouble with my canon copier ir 2870
E000602-0113 means that the hard drive is having problems booting up. You may try to remove the boot chip and clean the contacts with rubbing alcahol and reinstall it and turn the copier back on. Most likely you will need to replace the hard drive or try to re-flash the hard drive.
Posted on Mar 16, 2008
Cogz
  • 1326 Answers
SOURCE: error code e542
The error code means that the finisher bins could not find HP. The problem shows up when something is placed under the bins and stops them from moving down, most of the time a "G" file or a case of paper. Move the object and move the bottom bin up till you hear it click. Before doing that make sure the MAIN Power Switch is OFF on the right side of copier... Then turn the copier back ON and it should clear it self.. Good Luck
Posted on Apr 19, 2009
  • 66 Answers
SOURCE: error code c6400
The model of the copier is usually pretty important but try this and you should be up and running soon
type in 1087 1087
wait for the screen to show 000
type in 163 and hit the start button
you may seethe word execute on the screen (if so then select it and confirm with either the green button or the silver one)
this resets your fuser unit
if this does not work you will have replace parts in the fuser or replace the whole fuser unit
please take the time to rate this fix
Posted on Apr 23, 2009
canontech
  • 1219 Answers
SOURCE: error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
Posted on Jun 02, 2010
  • 170 Answers
SOURCE: hi every one.i have canon copier ir105 gives me
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Posted on Nov 22, 2010
Cannon it 2870 have error code E 00024-0000
Empty the waste toner .it's in the back of machine
Feb 11, 2017 | Canon IR 2870 Digital Copier RECONDITIONED
WHEN MAKING A FIRST COPY OF ANY DOCUMENT THE FOLLOWING ERROR APPEARS e000024-0001
Canon imageRUNNER 2870 Copier Error code e000024 ...
www.fixya.com > ... > Canon > Canon imageRUNNER 2870 Copier
... error code e000024-0001 E000024-001 is a problem with the developing assembly it's usually either a faulty toner sensor sometimes just toner stuck to it just ...
Sep 09, 2015 | Canon ImageRunner 3570 | IR3570 |
2870 canon copier machine showing error code E000024-0001
service manuals free at http://www.eserviceinfo.com may help you out .
Jul 03, 2015 | Canon IR 2870 Digital Copier RECONDITIONED
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Feb 22, 2011 | Canon ImageRunner 2020i Copier
Error code 19
May 19, 2010 | Canon ImageRunner 2020i Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
k24674
jasbo
jasbo
