Question about Miele 23 in. KM360G Gas Cooktop
No Spark - 99 Explorer 4.0 sohc - Miele 23 in. KM360G Gas Cooktop
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 40 Answers
Ok does it not have spark in all cylinders or just one? have you ran a test on it to pull any error codes? is the motor turning over? now those motors have timing chain issues have yu checked the timing chain?
Posted on May 09, 2014
No matter which knob I turn on, all 4 ignitors spark,
There is no fix. This is normal. All 4 ignitors will spark but the gas will only go to the burner where the gas is active.
Jun 11, 2014 | Amana AKS3040 Gas Cooktop
How to replace electric ignitor for outdoor grill?
it may be that the electricity or the spark is connection to different point of the grill, the electricity will spark to the closest point of conductivity.
if you check and each ignitor is sparking , strongly ( so no problem with spark modual), then there may be points in the wireing whichis exposed or more likely where the wireing and the ignitore connects,
you can tape it with electrical tape, then it should see the spark to the burner. if it is sparking, and not to the burner, just means it is sparking to a different point, where the jump is shortest.
Apr 18, 2013 | Cooktops
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
10-12 year old dacor 4 burner epicure cooktop --left front burner
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Electronic igniter stopped working
I recorded video to let u see how its done. Problem Was : non of the burners would ignite (no sparks when knob is turned on). First sigh of bad spark module, but I got spark switches(they harness) as well just in case - One of the spark switches was bad - Check my video how I replaced them. Non of the screws was coming out.
Nov 15, 2007 | KitchenAid 31 in. KGCS105 Gas Cooktop
Miele 23 in. KM360G Gas Cooktop Logo
75 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
