American modern central air unit phkjo481a manuals ?
American modern central air unit Model PHKJO481A or PHKJ0481A this seems to be impossible to find i ahve all the info from the unit, however there is one item blank, i would like to have this manual on file, for my records. Thanks
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
  • 230 Answers
SOURCE: Our central air conditioning unit
Sounds like a start run capacitor. The motor may be bad too. The capacitor will look bloated if it is bad. There may be other reasons for these parts to fail. So please call a licensed technician for professional help.
Posted on Jun 17, 2008
SOURCE: the rv air conditioner unit
Here's a link to SERVIVE MANUAL FOR 6535 SERIES TWO TON HIGH EFFICIENCY PACKAGED HEAT PUMPS (http://www.rvcomfort.com/pdf_documents/1976323_copy8.pdf) on the RVP website.
Posted on May 28, 2009
  • 34 Answers
SOURCE: How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
You need to take the cover off and you should see some aluminum fins like whats on the outside unit the blower will either blow across them or pull air accross them. Clean them with a wire brush and soapy water if you dont have coil cleaner which can be purchased at hardware stores
Posted on Aug 12, 2009
  • 20 Answers
SOURCE: Heil central air unit blower fan is not turning
It sounds like you have a bad capacitor. This will cause the motor to lag and not start. Good luck.
Posted on Aug 31, 2009
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
Rheem central air unit is blowing cold air but seems to be in low
If you have had a drop in how much air is coming out it is quite likely not fan related. The fan motors usually run or do not run. More likely it is a clogged air filter or some of your ducting has blown loose. Like water, air will go the route of least resistance. If your fan motor is not running at all, I would need model number for resolving that.
Jul 08, 2009 | Heating & Cooling
Need schematic for an American Standard A/C Model number 7A0030A1
American Standard and Trane are the same thing. The diagram you want is not complicated at all. Just straight cool unit. American Standard does not put low or high pressure controls on unit. You can get diagram on line At American Standard.com. Just what do you need to know? Very basic unit.
Jun 11, 2009 | Heating & Cooling
Can I get some help identifying ,or finding out who made,and or traded American IMC air compressors.Am looking for manual& IPL,for a model Tu 807?serial 19999. Unit is powered with a Briggs&Stratton 8.5 HP...
Here is a link for American IMC air compressor parts. The engine manual usually does not come with the compressor and can be found on the B&S website. Also unless you need a internal compressor part, most external parts such as unloaders, safety valve, pulleys, and piping are very generic and can be replace with aftermarket parts.
http://www.mastertoolrepair.com/compressors-manufacturer-american-c-271_79.html
Mar 29, 2009 | Air Tools & Compressors
Where is my a/c filter?
If your rooftop unit is self contained with no pipes leaving it except the condensate drain line there should be a narrow removable panel to access where the filters are located. If you have three pipes exiting the roof top unit two will go to an air handler located in the attic of the home. The filters will be located in the air handler.
Jun 13, 2008 | Heating & Cooling
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
