Question about Maytag Washing Machines
How do I reset a f21 error on my Maytag 5000 frontload washer?
    Genius:
  • 1,056 Answers
You don't just reset it; once you fix the problem it will reset on its own.
The problem is that it drain. I ran into the same kind of problem on my Frigidaire Affinity; in my situation a rag had gotten between the inner and outer drums and was blocking the drain. Here's a link to the video of how to fix yours:
Fix 21 33 Whirlpool Duet Sport Drain Pump motor problems
Posted on May 09, 2014
SOURCE: te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Posted on Jan 10, 2008
huuum
  • 750 Answers
SOURCE: Maytag Washer-EpicZ frontloader - error code F20
hi cybileyes,
Are you still having problems since July 01, 2008?
If you have a code the best and first thing you can do is unplug the washer for 5 minutes and then restart it the system should reboot or reset!
let me know what happens for you.
Bless You
HUUUM
Please remember to give a rating before you leave.
Thank You
Posted on Sep 22, 2008
zoe1979
SOURCE: F21 error on a whirlpool
error code f-21 is a simple fix on the front of your washer there is a lower panel that can be removed
with three screws. after removing panel you will see a white plastic piece/plug that you can unscrew
(be prepared for water spillage) remove that plug this is called the coin trap clean out this trap and put back together. this should solve your problem
Posted on May 10, 2009
kel1guy2002
  • 3740 Answers
SOURCE: getting f21 error on my front loading 3000 series
F21 is too long to drain:: (more than 4 mins) Check your drain hose outflow into a couple of 5 gal buckets it should flow pretty fast. If not, there is both a suds sensor and the water level pressure switch that can be causing the problem. Since you do not have SUDS showing on your control panel I am assuming the suds sensor is fine. The water pressure switch itself can cause the problem even if you hear audible clicks when testing with an external hose. A clogged drain pump strainer can do the same thing. Lastly... the obvious... is the drain hose kinked???? Good luck and hope this helps.
Posted on Jan 11, 2010
jsrock516
  • 5911 Answers
SOURCE: my maytag 5000 series steam
"F21" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. On some model washers there is no screw off cap on the pump and you will have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Removing the inlet hose for inpsection is recommended on all these washers just to ensure there isn't anything lodged in the line. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: The washer will not complete a wash cycle until the conditions causing the error are corrected. In addition, a "SUD" or "SD" (Suds lock) error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
NOTE: If you determine the pump to be defective, and the pump housing is still in good condition, you only need to replace the pump motor. However, the pump is usually sold as an entire assembly and the motor CANNOT be orderd as a separate item. There are several outlet stores that advertise on ebay and sell the pump motor for much less than ordering an entire pump assembly. Replacement is simple and you do not have to remove the pump from the washer. Just drain the pump as previously mentioned and disconnect the electrical plug from the motor. Remove the three screws holding the motor to the pump housing and replace as necessary. Just make sure the o-ring is intact and in place. To get a good seal, you can lubricate the o-ring with a thin film of petroleum jelly.
NOTE: Newer model Maytag washers are manufactured by Whirlpool. These instructions apply to Whirlpool Duet, Kenmore Elite and Maytag Epic series appliances.
Posted on Mar 17, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
I have an F11 error code on my maytag frontload washer?
It sounds like a control unit has burned out. There is a computer that speaks to the motor to tell it what to do. If you reset it and a part is bad the computer will still recognize the problem and thus resend error message.
May 04, 2014 | Maytag Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
My maytag washer is showing F21. Won't empty of
Hello, welcome to fixya.
Based on your post I understand you have a "F21" error problem with a Maytag washer, the error on these units built by Whirlpool (such as yours) means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
Sep 01, 2011 | Maytag Washing Machines
What does an F21 error message mean in a Maytag 5000 series front load washer>
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 15, 2011 | Maytag Washing Machines
My frontload washer keeps saying f21
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Feb 27, 2011 | Washing Machines
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
This is a frontload Neptune. I think you will find that the motor control located in the bottom right front of the cabinet is bad.
Feb 07, 2009 | Compaq Presario 5000 PC Desktop
Washing Machines Logo
287 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
