Question about Breville Kitchen Appliances - Others
How do I properly clean inside the toaster?
There are crumbs above where the tray pulls out to clean. can I unscrew the four screws underneath it to get inside? Thanks
5 Suggested Answers
SOURCE: after cleaning crumbs (turning over also) toaster
bought a new toaster... thanks for the help... ?
Posted on Oct 24, 2009
  • 351 Answers
SOURCE: clean out bottom
Hi .. turn the toaster upside down. There should be an access door there to allow you to clean out the bottom of the toaster.
Posted on May 04, 2010
espressonist
  • 1711 Answers
SOURCE: Crumbs stuck on the sides and bottom of toaster
You can follow the instructions on how to replace the heating elemnts of the dualit toaster in the link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
With this way you remove yours clean the toaster completely and put the elemnt back.
Good luck
Posted on Jul 26, 2010
SOURCE: Dualit 20247 2-slice crumb tray needed
One way is to buy some thin gauge aluminium sheet and cut and bend. Cheap, and gives a sense of achievement if you like that kind of thing
Posted on Jan 31, 2012
Model TQ-800H gets toohot and shuts off.
i've found this to be a common problem.... typically, people will clean out the crumb tray at the bottom of the toaster, whilst other crumb bits remain elsewhere inside the toaster, especially close to the heating elements, and alot of newer models today have a safety sensor. try giving it a good thorough cleaning and visual inspection to rule out a little excess building getting in your way...literally. lol. hope this helps
May 09, 2016 | Hatco Kitchen Appliances - Others
Tip
Procedure for replacing heating elements for Dualit Bread toaster
91b14ba.jpg370ea57.gifPROCEDURE
PROCEDURE FOR REPLACING ELEMENTS
A. Disconnect the toaster from the mains
B. Remove the crumb tray.
C. Unscrew feet and remove base plate.
D. D. Loosen the two nuts and slide back element retaining strip.
E. Note the position of the connecting links and wires, then unscrew nuts which secure them to the broken element, bend back the connecting links, pull out the old element and slide in the new element. Fasten connecting links back to their original position by tightening the nuts.
F. Slide back element retaining strip and tighten nuts.
G. Make sure that you have the high wattage elements marked ?CENTRE? in the middle and the two low wattage elements marked ?END? at ends.
H. Refit base plate, feet and crumb tray
on Apr 02, 2010 | Kitchen Appliances - Others
Kitchen aid toaster won't stay down, heats when held down, but only on bagel setting. Checked crumb tray but all clean. What to do?
Contacts may be coated with Burt oil, butter, other matter. When engaged, contacts aren't engaging.
Aug 31, 2014 | Kitchen Appliances - Others
How to clean the inside of a toaster
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Nov 21, 2013 | Dualit CTS4E 4-Slice Toaster
Just purchased toaster oven model CE23551 and it did not have a crumb tray as advertised on the box and owner manual. Why is there no crumb tray ?
This model does NOT come with a crumb tray. In order to remove the crumbs from the bottom it must be shaken (like a toaster). I understand that this may be a little inconvenient; however, this machine is made relatively light weight for that purpose.
Mar 30, 2013 | Toaster Ovens
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
Jul 28, 2011 | Braun HT600 2-Slice Toaster
Replaceing the small pull out tabs on the crumb tray
You can find these parts on E-Bay
http://cgi.ebay.com/PARTS-00322-DUALIT-TOASTER-CRUMB-TRAY-HANDLES-2-PK-/130287387597?pt=UK_Home_Garden_Kitchen_Toasters&hash=item1e55bbc3cd#ht_3490wt_883
Apr 02, 2011 | Dualit 20084 2Slice Toaster
Good luck
Jul 24, 2010 | Dualit CTS4E 4-Slice Toaster
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Mar 27, 2007 | Krups 288 SensoToast Compact 2-Slice...
Kitchen Appliances - Others Logo
32 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
