Question about Canon Office Equipment & Supplies
Canon PC785 fails and turns off immediately after turning on. Displays code ''EO'' just befor shutting off
    President:
  • 1,126 Answers
E0 error means Fixing Unit failure. It could be a dirty Thermistor. It could be an open Thermal Fuse. It could be an open Heater Lamp. Anyways, once the culprit has been isolated and corrected, the copier will need to be reset via "jumpering" certain points on DC Controller.
Posted on Jun 23, 2009
When turn on the the copier, it flash "EO" green
An E0 is a fixing unit error. The fixing unit needs to be replaced.
Nov 17, 2010 | Canon PC-920 Black and White Copier
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Canon copier pc785 e0 07
E007Fuser film off track and will not repair itself, Apply to service
Sep 19, 2009 | Office Equipment & Supplies
Canon copier PC785 displays E0 and turns off
fuser unit is located near the printing
output
Sep 02, 2009 | Canon Office Equipment & Supplies
EO code illuminates when power button is pushed, then immediate shut down
Check the fixing thermistor and thermofuse.This code indicated a malfunction in the mai power and fuser unit section.You have one shortcircuit or open circuit in this parts.
Aug 28, 2009 | Canon PC-735 Copier
When I turn the PC785 on, EO flashes and the unit turns off.
Hello sir; You don't need the parts, the only thing you need is reset, the procedure as follow; Turn power off, remove front cover, short JP1 to JP2 on DC controller (upper right corner of board), turn power on, the display may show a different code,repeat the reset procedure.
Aug 11, 2009 | Canon Office Equipment & Supplies
We have a Canon NP 6050 copy machine. When you put the plug in the socket, machine is only on for less than one second, then automatically shut off by itself.
I forgot one thing, if it turns OFF before it displays the error code Hold the power switch ON till it shows the code...... I'm thinking it maybe a E0200 or E0210 that is a scanning lamp or it could be a broken fixing lamp.... I'm guessing....
Nov 19, 2008 | Canon NP 6050 Copier
Canon pc-6re error code EO 10
E010 Clock pulses fail to be generated or the PLL lock fails to be released due to a fault in the main motor, etc. Related drum drive unit and main drive unit
There is a problem with the motor of the drum or the main motor itself.
Nov 08, 2008 | Canon IMAGERUNNER 6570 Copier
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Aug 01, 2008 | Canon PowerShot S3 IS Digital Camera
142 people viewed this question
old marine
old marine
