Question about Saeco Incanto Classic Espresso Machine
Giro odea plus not switching on and brewing unit stuck
Giro odea plus brewing unit is stuck and the unit isn't switching on anymore
  • richard
    richard May 09, 2014
    The manual say: Press the brew button to start the machine.
  • richard
    Manual says: Turn the machine on. Close the service door. The brew group is automatically placed in the correct position. But If I can't get the machine one I can't resolve the brewing unit problem, right?
    New Friend:
Your Main power board is most likely gone I could power mine up though. I had used a card to reset the brew group but the error was far more serious, It cost me $350 to have a new power board but the repairer was a bit unsure if I should spend the money and left it up to me, after repairing it he said it is an extremely good coffee maker and I should get the next 6-8 years out of it. they are the last model in this range that was built in Italy and it is worth fixing in my opinion because if you go out and buy something to replace it it will likely cost $$$$ to get one as good. The repairer also commented on the quality of the coffee it makes he was very impressed by this machine so your choice. I also found another one on ebay and purchased it for a $200 it is in great condition but I now have parts and can run two types of coffee :) hope this helps. Kind regards Jen
Posted on May 10, 2014
Testimonial: "Thanks"
    New Friend:
Check the power cord, switcher and wires to control panel
Posted on May 11, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Follow the steps in the manual if you have a manual and if you don't have one I recommend that you get one.
Posted on May 09, 2014
  • 70 Answers
SOURCE: odea giro plus gear that drives the brew group has broken 3 times
The coffee is being ground too fine usually. Also not cleaning the brew group and lubricating it regularly can cause this.
The gears are standard plastic and any excessive force will cause them to break. The only things that cause excessive force to gears on saeco machines is fine coffee compacting in the brew group and/or a dirty brew group that gets stuck and does not cycle properly.
Posted on Sep 10, 2009
  • 81 Answers
SOURCE: Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Posted on Jan 21, 2010
  • 81 Answers
SOURCE: My apparatus SAECO ODEA GIRO doesn't light on
Thermal switch has tripped on the boiler and can be reset by pushing in the pin. Or more seriously can be the circuit board failure.
  • 81 Answers
SOURCE: How can i reset de saeco odea giro plus ?
Only way is to open the side panel where you place the brewunit and realign the splines with the unit.
espressonist
  • 1711 Answers
SOURCE: the machine odea giro plus whistle while brewing
The scale in the pipe system have norrow at some points so while brewing and with hight pressure you here the whistle.
First I sugest to descale the machine and you may try to do it for three days repeatevly.
However if the noise will not decrease then the machine need full desasemble and remove the scale manualy. But I advice only to do the above if you have problem with the coffee quality or if the noise is so strong and can not bair it any more.
Posted on Jun 05, 2010
Testimonial: "thanks"
Hi, I've got a saeco odea giro plus. 3 weeks old, the descaling ight came on. I followed descaling steps in manual. rinsed off brew group and place it back in unit. now the system will prime, grind, I...
Look at the brewing group where the top strainer is. The small holes are blocked with coffee. The water can not pass through them.
You will need to unfold the two screws at the top and then remove the strainer, grow and clean it and clean it if the holes are blocked.
Do this only
Apr 29, 2017 | Saeco Odea Giro Plus Coffee Maker
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
We have an Odea Giro in the office. When we got it I remember the coffee tasted amazing. After few months the taste started to decline and after some time we stopped to use it altogether. I wanted to...
you are supposed to go through the "before first use" instructions....which include filling the resevoir with water and brewing only water until its all gone. then start using the machine normally...remembering that the machine takes a few brew cycles to adjust properly to the coffee being used (this assuming this is the giro plus model which has the feature-"aroma something or other...)
also, descaling would help and removing the brew group and rinsing it out...
Nov 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
How can i reset de saeco odea giro plus ? I can not place the central unit because the axes or spindle is not in the right position.
Turn off the machine. Open the side panel, remove the dreg tray, remove the dreg box and remove the brew group. reinsert the dreg box without the tray. Using a flat head screw driver insert lightly into the slot where the brew group sensor is until you hear a click. Hold the screw driver in place while closing the side door and turning it on. The head will re-align. Now open the side panel, remove the box and reassemble. Leave the machine off for an hour and turn back on. That should reset it.
Jan 10, 2010 | Saeco Odea Giro Plus Coffee Maker
My apparatus SAECO ODEA GIRO doesn't light on anymore Thanks for your help
Jan 09, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco odea giro. I can not put back the brewing system
Make sure that the brew unit gears is set on the N, check the little arrow next to the handle. Then check the rotation of the machine, by turning it on closing the door so that it can reset itself. Then look at the gears in the machine and the one that will insert from the brew unit if the big one lines up you're good if not then you will have to take it to your nearest dealer to have it reprogrammed.
Nov 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Red ! flashes constantly
The lube is for the o-rings on the brew unit, and the ones on the white plastic valve behind the brew unit. As for the light there might be something a little coffee grounds keeping the door open.
Sep 14, 2009 | Saeco Odea Giro Plus Coffee Maker
Machine stoppped working
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Jun 25, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Incanto Classic Espresso Machine Logo
71 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
