Question about Fafco Pool & Spa
What causes a fafco error code s2
I have a "Auto Pool" system with an "Auto Pure" Module
You can ask some professional tech staff, who can tell you more details
Posted on Jun 04, 2014
E70 and E90 error code on intex pure spa pump... what do these mean and how do I fix it?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check with Intex for a repair manual ( On line and google..)
Feb 25, 2016 | Intex Pool & Spa
Had my roof replace so had plumber remove solar panel and reinstall now the water does not circulate and the system just flashes
The two pipes that connected the pump system to the solar heater were probably capped and they should have been connected to cause normal water flow. I hope this helps.
Aug 21, 2011 | Fafco 2 PANEL DELUXE SOLAR HEATING SYSTEM(...
I have 2 inch PVC system for my pump and filter. Fafco inground system has 1.5 inch piping. Where is the best way to reduce 2 inch pipe to 1.5 inch (at the diverting valve or at the panel)? Another...
Honestly, I think you are over thinking both your problems. Reduce to 1.5 inch pipe as close to the ground as possible. It is more work for your pump to push water up a 2" pipe then a 1.5" pipe, but it will do either without any real problem.
As far as mounting your panels, as long as they are above the water level of the pool the water is going to drain out of them just fine. You can slope them slightly, but you don't need to.
Apr 16, 2011 | Fafco Inground Deluxe Solar Heating System...
I have an error code S2. what does that mean?
Did you ever get an answer.
I get the same error code. "S2"
Jan 09, 2011 | Fafco 2 PANEL DELUXE SOLAR HEATING SYSTEM(...
How to setup a diverter valve for above ground
If you want all your water going thru the solar heater before re-entering the pool, you'll need to plumb the end of your filter to the solar heater, then the water exiting from the solar heater would go where the filter hose did go back into the pool. Hope this helps.
May 25, 2010 | Fafco Deluxe Solar Panel Heating System 1...
Can pex be used on sungrabber systems
Pex degrades quickly when exposed to UV, never use(or store) pex in direct sunlight. Even indirect sunlight can do damage.
Feb 11, 2010 | Fafco Sungrabber Standard Above Ground...
My fafco solar panel is now a warm water fountain spray system. There are a small number of pinholes. What's the best way to repair this? - Epoxy - Plugs - ?
you can contact fafco or heliocol and get a plug kit. its a rubber plug that once you cut the tube you insert the plug into the tube and then insert an expansion peg behind it to help it stay in place.
Sep 24, 2009 | Fafco Sungrabber Standard Above Ground...
Support of 4x20 panel
The picture obscures the fact it is mounted on plywood panels which are leaned against the pool.
The manufacturer does not offer any sort of support for it. You'll need to install it however it bests fits your pool/yard.
Jun 02, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Fafco Solar Panel system - how to bypass sensor?
I would, put a quarter turn ball valve in the sensors place.
Apr 14, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Pool & Spa Logo
70 people viewed this question
Top Fafco Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Fafco Pool and Spa Expert? Answer questions, earn points and help others
